Rotella T 15W40 #1474843
07/27/13 03:48 PM
07/27/13 03:48 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
I was told to run Rotella T 15W40 as the engine oil that I should use because it is high in zinc, any input on that?
Re: Rotella T 15W40 [Re: tee-john] #1474844
07/27/13 03:57 PM
07/27/13 03:57 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Thats what just got used in my 92 Dakota 5.2 this morning.
I switched to the diesel oil when I bought it to help it last longer, and since I drive interstate 60+ miles a day.
I have used it in many different gas engines with no harmful results.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Rotella T 15W40 [Re: tee-john] #1474845
07/27/13 04:12 PM
07/27/13 04:12 PM
Locomotion Offline
Locomotion  Offline
I don't have the specific numbers, but most oils have been getting reductions in zinc over the years, including diesel oils. One needs to do some research to keep up with the latest. Can't take it for granted. Best oils will be advertised as having extra zinc.
The zinc is mainly to protect flat tappets. But zinc has an adverse affect on the newer catalytic converters which is why they started removing it.
Re: Rotella T 15W40 [Re: Locomotion] #1474846
07/27/13 04:18 PM
07/27/13 04:18 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
The zinc is mainly tom protect flat tappets. But zinc has an adverse affect on the newer catalytic converters which is why the started removing it.
While Rotella is a great oil that I use in everything from my diesel Ram to my ATV's and motorcycles the amount of zinc has been reduced over the years.
I would research what zinc levels are currently in the 15w40 oil and see if your satisfied, you might find you still need a zinc additive.
Re: Rotella T 15W40 [Re: KillerBee] #1474847
07/27/13 04:29 PM
07/27/13 04:29 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I use Rotella in a lot of my vehicles, but those with FT cams get zinc additive too; as noted, Rotella has less zinc now. Only the specialty oils have the old levels.
Re: Rotella T 15W40 [Re: topside] #1474848
07/28/13 01:01 AM
07/28/13 01:01 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i would use valvoline VR1 10/30 if its a new tight engine or 20/50 if its got some miles on it.
Re: Rotella T 15W40 [Re: ademon] #1474849
07/28/13 01:13 AM
07/28/13 01:13 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
These are good oils for flat tappets without going to an expensive oil. Don't spend too many brain cells on Zinc,ZDDP or other myths or additives.
