B Body HP Manifolds in a C Body #1474459
07/26/13 05:29 PM
07/26/13 05:29 PM
Back In Iowa
belv2vert66 Offline OP
Back In Iowa
Will B Body HP exhaust manifolds work in my 65 Newport ? I might be crazy but finally building this car. Stroking the 383 to 438
Re: B Body HP Manifolds in a C Body [Re: belv2vert66] #1474460
07/26/13 05:57 PM
07/26/13 05:57 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Passenger side manifolds are the same. Drivers side has a different output location. Not sure if it will have a clearance issue with the steering column. Best thing to do is mock them up and see if it clears everything.
Re: B Body HP Manifolds in a C Body [Re: belv2vert66] #1474461
07/26/13 05:59 PM
07/26/13 05:59 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Yes, I had a set in my 66 Newport with a 383. If I remember right, the driver side pipe took kind of a sharp turn right out of the manifold,but nothing super severe. You'll have to fabricate pipes or have an exhaust shop do it,don't think anyone is gonna have those for sale pre-bent.
Re: B Body HP Manifolds in a C Body [Re: 67_Satellite] #1474462
07/26/13 11:10 PM
07/26/13 11:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Driver's side c-body HP manifolds are not that hard to find nor are they expensive.
Re: B Body HP Manifolds in a C Body [Re: 6bblgt] #1474463
07/27/13 12:19 AM
07/27/13 12:19 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The exhaust will route different than stock, but that is the only problem. I ran them in my old 69 Polara wagon (383).
Re: B Body HP Manifolds in a C Body [Re: Jim_Lusk] #1474464
07/28/13 12:00 PM
07/28/13 12:00 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I happen to have 2 driver's side HP C-body manifolds. You are welcome to one of them if you need it.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: B Body HP Manifolds in a C Body [Re: bschargerse] #1474465
07/28/13 11:20 PM
07/28/13 11:20 PM
Back In Iowa
Back In Iowa
Thanks everyone ! picked a set up today local. On to the next C body problem to solve.
