Brake Wiring Question? #1474450
07/26/13 05:20 PM
07/26/13 05:20 PM
abc440 Offline OP
abc440  Offline OP
I have a 71 Charger. Bought a cool looking license frame with led lights. How it is soppose to work is white lights that are hooked up to running lights on car, and turns to red lights when brakes applied, and 1 wire to ground. It works fine when just hooked to a 12 v. battery. I also hooked it up to my 2003 truck and worked fine. It is a Pilot LW704-RW part number. Is there something different on how my car's brakes are wired maybe grounds as opposed to my truck?
THANKS Dave
Re: Brake Wiring Question? [Re: abc440] #1474451
07/26/13 08:28 PM
07/26/13 08:28 PM
I'd think the running lights would go to the license plates white light(s) positive terminal & the brake light switch white wire would go the red lights to fire them when the brake pedal is depressed. The case of the red and white lights or their neg terminal to ground. The white lights would be on anytime the running lights are on & the red lights would be on when the brake pedal is pushed Sound simple but I feel I'm missing something. Me I think it'd be cool to have em flash with the blinkers & not sure how I'd make that work
Re: Brake Wiring Question? [Re: RapidRobert] #1474452
07/26/13 08:53 PM
07/26/13 08:53 PM
abc440 Offline OP
abc440  Offline OP
Thanks Robert. It sounds simple, but I bought a second one to make it wasnt the light bad. It comes 3 wires-1 groung, 1 wire to running lights, and 1 wire to brake light. The running light(white leds) works with light switch, but red leds or white leds will not work with brake pedal pushed. Tested on truck just fine, and with extra battery I had. (I can touch ground to neg posts, wire for running light white leds good, and touch red also at same time and go to red leds for brakes as they are suppose to). I just tried again, going crazy. They would be nice if they worked. Right now running wire for red leds to running lights. looks ok. Thanks dave.
Re: Brake Wiring Question? [Re: abc440] #1474453
07/26/13 09:37 PM
07/26/13 09:37 PM
The reds work when fire is fed to them ONLY when fire is fed to the white ones? I'm going crazy too
Re: Brake Wiring Question? [Re: RapidRobert] #1474454
07/27/13 09:23 AM
07/27/13 09:23 AM
abc440 Offline OP
abc440  Offline OP
The red leds will fire when hooked to parking light, but will not fire when hooked to one of the brake wires in the trunk. also red or white will not fire when hooked to brake wire, but 12 volt test light will fire when touching brake wire.
Re: Brake Wiring Question? [Re: RapidRobert] #1474455
07/27/13 05:39 PM
07/27/13 05:39 PM
abc440 Offline OP
abc440  Offline OP
Hey, I think I just discovered my problem. Dumb me, I just hooked a volt meter to brake wire in trunk and only had 6.9 volts. I can start car and at idle have 9 volts and led lights on license frame work like they suppose to. That explains why they would work when hooked straight to battery. I was just using a 12 volt trouble light to test with. Is that amount of voltage to trunk brake wires normal, or how can I get more. My oringal brake lights work ok, even with car not running. Any suggestions? Thanks Dave
Re: Brake Wiring Question? [Re: abc440] #1474456
07/27/13 07:22 PM
07/27/13 07:22 PM
That would have got by me as I did not know that LED lights needed more voltage than regular lights in fact since they're more efficient I'd have thought the opposite that they work on less. That is REAL LOW voltage tho. I'd double check the meter readings by running the ground lead all the way up to the batt neg post. I'd clean EVERY connection & I'd see what I have for charging voltage at a fast idle at the batt & at the alt & see what you have at the bulkhead/fuse box etc & go from there rearward. Any terminal/connection is a potential voltage drop from high resistance
Re: Brake Wiring Question? [Re: RapidRobert] #1474457
07/27/13 07:31 PM
07/27/13 07:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You should have battery voltage,12v+,at the rear lights.
Re: Brake Wiring Question? [Re: RapidRobert] #1474458
07/28/13 06:56 PM
07/28/13 06:56 PM
abc440 Offline OP
abc440  Offline OP
I ran a groung wire straight from battery (not running) and got 7 volts at brake wire in trunk. Checked voltage on battery not running and got 12.25 v, got 13.5 volts with motor running at 1500 rpms. Tried to check voltage at alt (3 wires) not sure which wires to touch and a little intimidated. To be honest, I hate to bother bulk head connection if no other problems. Thanks Dave
