turn signal cam install #1474369
07/26/13 01:39 PM
07/26/13 01:39 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
The turn signal cam in my 69 GTX cracked in two. I received a new cam through ebay. The stud the cam slides on-too has retaining flanges on each end. These flanges are preventing the cam from sliding over the stud. I see no way to remove these flanges therefore I cannot install the cam. What am I missing here? How is this cam installed without damaging it?
Re: turn signal cam install [Re: frank] #1474370
07/26/13 02:46 PM
07/26/13 02:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about a picture to see what you are dealing with. Some thing in the description is odd.
Re: turn signal cam install [Re: stumpy] #1474371
07/26/13 02:57 PM
07/26/13 02:57 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I just replaced mine for my Dart a little under a year ago and may be able to help. I just can't recollect what it all looked like. It helped me to download the factory service manual.
Re: turn signal cam install [Re: MuuMuu101] #1474372
07/26/13 03:43 PM
07/26/13 03:43 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
this is the stud the cam gets mounted on. Notice top and bottom
Re: turn signal cam install [Re: frank] #1474373
07/26/13 03:44 PM
07/26/13 03:44 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
this is the cam. Notice no slots
Re: turn signal cam install [Re: frank] #1474374
07/26/13 03:45 PM
07/26/13 03:45 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Try again
Re: turn signal cam install [Re: frank] #1474375
07/26/13 04:10 PM
07/26/13 04:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks to me like you have pushed the stud down into the switch.
Re: turn signal cam install [Re: stumpy] #1474376
07/26/13 05:57 PM
07/26/13 05:57 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
That's exactly the way it was when I removed the broken cam. If you buy a new turn signal switch you get the assembly; cam and switch. There has to be a correct way to install this cam
Re: turn signal cam install [Re: frank] #1474377
07/26/13 06:12 PM
07/26/13 06:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Normally you just start the cam on the stud and pull it down using the screw that goes through it to the signal lever.
