turn signal cam install #1474369
07/26/13 01:39 PM
07/26/13 01:39 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
The turn signal cam in my 69 GTX cracked in two. I received a new cam through ebay. The stud the cam slides on-too has retaining flanges on each end. These flanges are preventing the cam from sliding over the stud. I see no way to remove these flanges therefore I cannot install the cam. What am I missing here? How is this cam installed without damaging it?
Re: turn signal cam install [Re: frank] #1474370
07/26/13 02:46 PM
07/26/13 02:46 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
How about a picture to see what you are dealing with. Some thing in the description is odd.
Re: turn signal cam install [Re: stumpy] #1474371
07/26/13 02:57 PM
07/26/13 02:57 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I just replaced mine for my Dart a little under a year ago and may be able to help. I just can't recollect what it all looked like. It helped me to download the factory service manual.
Re: turn signal cam install [Re: MuuMuu101] #1474372
07/26/13 03:43 PM
07/26/13 03:43 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
this is the stud the cam gets mounted on. Notice top and bottom
Re: turn signal cam install [Re: frank] #1474373
07/26/13 03:44 PM
07/26/13 03:44 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
this is the cam. Notice no slots
Re: turn signal cam install [Re: frank] #1474374
07/26/13 03:45 PM
07/26/13 03:45 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Try again
Re: turn signal cam install [Re: frank] #1474375
07/26/13 04:10 PM
07/26/13 04:10 PM
Grand Prairie,Texas
Grand Prairie,Texas
Looks to me like you have pushed the stud down into the switch.
Re: turn signal cam install [Re: stumpy] #1474376
07/26/13 05:57 PM
07/26/13 05:57 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
That's exactly the way it was when I removed the broken cam. If you buy a new turn signal switch you get the assembly; cam and switch. There has to be a correct way to install this cam
Re: turn signal cam install [Re: frank] #1474377
07/26/13 06:12 PM
07/26/13 06:12 PM
Grand Prairie,Texas
Grand Prairie,Texas
Normally you just start the cam on the stud and pull it down using the screw that goes through it to the signal lever.
