lifter chatter #1473984
07/25/13 12:01 PM
07/25/13 12:01 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I'm new to the stock stuff I'm used to solid roller valve lash etc....I will get to the point ...I have a fresh 440 rebuilt by a friend and this thing sounds like it has Rhoads lifters ...which it doesn't ...comp cams equipped and after the engine warms up it chatters a lot ...stock heads aluminum roller rocker arms its quiet when its cold but after warming its annoying
Re: lifter chatter [Re: 10secGTX] #1473985
07/25/13 01:50 PM
07/25/13 01:50 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
It seems to be a a common issue with a comp cam , which cam do you have ? what lifters , how much preload ?
Re: lifter chatter [Re: 10secGTX] #1473986
07/25/13 01:59 PM
07/25/13 01:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Aluminum heads out grow the pushrods hot so 6 thou or tighter lash is probably on order.
Hydraulic try 1/2 turn more pre load that should do it if not another 1/2
Re: lifter chatter [Re: JohnRR] #1473987
07/25/13 02:12 PM
07/25/13 02:12 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
COMP cam kit XE275HL-10... its 525 with split duration 275 in/287 exh ..its a kit so i dont know the exact part # for the lifters. cam is degreed @ 107.6 int centerline Cast / stock heads
Re: lifter chatter [Re: 10secGTX] #1473988
07/25/13 02:22 PM
07/25/13 02:22 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I have a Compscam cam and lifters that do the same thing.
Re: lifter chatter [Re: markrr] #1473989
07/25/13 02:28 PM
07/25/13 02:28 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Mine with an Erson sounds like it has solid lifters, but it doesn't.
Re: lifter chatter [Re: 10secGTX] #1473990
07/25/13 04:59 PM
07/25/13 04:59 PM
What double R and Dodgem said, see how much preload you have now & increase it slightly & see what happens. Holler how it goes
Re: lifter chatter [Re: 10secGTX] #1473991
07/25/13 10:35 PM
07/25/13 10:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have had ZERO issues with CC's lifters, Can't say the same for cheaper offerings. They are actually a 1st choice for me because of NO Issues.
I do run a shop and again ,They are actually a 1st choice for me because of NO Issues.
Re: lifter chatter [Re: TJP] #1473992
07/26/13 12:06 AM
07/26/13 12:06 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
If you are running a lower viscosity oil, something higher may make a significant difference.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: lifter chatter [Re: 10secGTX] #1473993
07/26/13 12:17 AM
07/26/13 12:17 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Whats the hot idle oil pressure? Does it clatter at idle or all the time? May have some loose clearance issues bleeding off pressure that are worse when hot. Other comp hyd cams I have had make a little noise I think because of the ramp designs, but not enough to be annoying. Maybe try an HV oil pump if not running one already?
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: lifter chatter [Re: 10secGTX] #1473994
07/26/13 12:32 AM
07/26/13 12:32 AM
How are you setting the lash or lifter preload on your motor? Hot or cold, setting it with the motor running or off and so on
Re: lifter chatter [Re: Cab_Burge] #1473995
07/26/13 04:44 PM
07/26/13 04:44 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I went to set the lifters cold ...and found the driverside of motor ok and gave them a 1/4 turn more of preload ..I went to passenger side and 6 out the 8 were no longer pumped up !!!!
Re: lifter chatter [Re: 10secGTX] #1473996
07/26/13 07:13 PM
07/26/13 07:13 PM
What type rocker arm and the size of the adjuster(3/8x24 TPI or 7/16x20 TPI) are you running? If the 3/8 x 24 each full turn of the adjuster is right at .042, the 7/16x20 is right at .050 so 1/4 turn on the 3/8 is right at .0105, probally not quite enough preload hot with cast iron or aluminm heads Setting the lash on a hydraulic cam and lifters can be very challenging, been there done that Try warming up the motor first so you can set one side of the motor at a time and try using the method to set the intake valves when the exhaust valve just starts to open when turning the motor over clockwize, I use the starter with a remote starter button, bump it around very carefully until the exhaust rocker arms just starts to open and then set the intake lash by backing the adjuster off until you get some slack between the rocker arm and valve, reach over the rocker arm with your fingers and turn, spin, the exhaust pushrod while you slowly tighten the adjuster up, once you get to zero lash, very slight tension on the pushrod try setting the preload a 1/2 turn more To set the exhaust valve preload turn the motor over until the intake valve opens all the way and starts to cloes, then set the exhaust Do one pair at a time and when your done with that one side put the valve cover back on and run the motor for several minutes more to get some heat back in the other side
Re: lifter chatter [Re: Cab_Burge] #1473997
07/26/13 11:32 PM
07/26/13 11:32 PM
Monroeville Ohio
Traven Offline
Traven  Offline
Monroeville Ohio
Personally I always set my lifter preload at.030". If I remember correctly, most manufacturers want between.020" and.060". If unsure of 0 lash setting use a.005" feeler blade set like a solid lifter and indicate the other.025". A little time consuming first time going it but you'll know exact preload and that all are equal.
Re: lifter chatter [Re: Traven] #1473998
07/26/13 11:36 PM
07/26/13 11:36 PM
Monroeville Ohio
Traven Offline
Traven  Offline
Monroeville Ohio
My mistake, indicate the .035" or desired preload.
Re: lifter chatter [Re: 10secGTX] #1473999
07/27/13 04:04 AM
07/27/13 04:04 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
since the friend did the engine ,ask if it has oil restrictors installed.. you would/may be surprised......
Re: lifter chatter [Re: Cab_Burge] #1474000
07/27/13 03:35 PM
07/27/13 03:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
been doing it that way since it was taught to me 40 years ago,
I will only add while rolling the pushrod and turning the adjuster you will distinctly feel the difference in resistance when you hit zero lash, even if the lifter is not pumped up you will feel the spring tension under the plunger
