Bronze tip pushrod for roller cam on BB #1473854
07/25/13 03:35 AM
07/25/13 03:35 AM
Sweden
Mopar Guy Offline OP
Sweden
Is there anybody out there that have any experience on how long a bronze tip pushrod for the fuel pump will hold ? It is a Comp Cams if that matters on a RB !?
Re: Bronze tip pushrod for roller cam on BB [Re: Mopar Guy] #1473855
07/25/13 11:43 AM
07/25/13 11:43 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
A lot of hyd roller and some mild solid rollers are being ground on cast cores.If the cam core is cast,you don't need a bronze tip. Only if the core is billet steel do you need a bronze tip.
Re: Bronze tip pushrod for roller cam on BB [Re: fbs63] #1473856
07/25/13 01:09 PM
07/25/13 01:09 PM
Stewart Water pumps in North Carolina makes the best fuel pump push rod with bronze tip--material sourced from England or some such--Nascar quality unit for 1/2 the $$ of mancini , Comp etc BEST unit out there Call Todd Marsh Moparts Connection see if he has one on shelf
Re: Bronze tip pushrod for roller cam on BB [Re: ] #1473857
07/25/13 03:21 PM
07/25/13 03:21 PM
California
mickm Offline
mickm  Offline
California
i need to double check, but i'm sure that is the one that i bought.
Re: Bronze tip pushrod for roller cam on BB [Re: mickm] #1473858
07/28/13 11:35 AM
07/28/13 11:35 AM
Sweden
Sweden
Thanks Guys but what i whas looking for whas how long that type of pushrod will last so if anyone know i would apriciate the info !
Re: Bronze tip pushrod for roller cam on BB [Re: Mopar Guy] #1473859
07/28/13 11:27 PM
07/28/13 11:27 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Don't you want a hard polished surface on the end of your fuel pump pushrod? Soft material collects particles that wear the cam core and then that just kills the soft tip of the pushrod.
Re: Bronze tip pushrod for roller cam on BB [Re: scatpacktom] #1473860
07/29/13 07:24 AM
07/29/13 07:24 AM
Sweden
Sweden
This cam is a roller cam made in forged steel so a bronze tip pushrod is recomeded and a bronze drive gear for oilpump ! Cast camshafts use steel harden tips and cast steel drive gear for oilpump
Re: Bronze tip pushrod for roller cam on BB [Re: Mopar Guy] #1473861
07/29/13 08:34 AM
07/29/13 08:34 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I realize what it is. I think you are better off with two hard metals is all.
Re: Bronze tip pushrod for roller cam on BB [Re: scatpacktom] #1473862
07/29/13 01:23 PM
07/29/13 01:23 PM
Sweden
Sweden
I heard that that combo would wear down fast and distroy the cam lobe for the rod and engine builders recomend bronze tip so i put that in to be shore but no one seams to have chekt the wear and mabe this hold like for ever !?
