Dart hood same as..... #1473516
07/24/13 10:25 PM
07/24/13 10:25 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
A friend of mine needs a new hood for his 1973 Dodge Dart Sport 340. If I remember it's the same hood as a 69 barracuda?
Re: Dart hood same as..... [Re: Coronet-R/T-Rag] #1473517
07/24/13 11:19 PM
07/24/13 11:19 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
I don't see how it could be... The Barracuda had a bump nose, but the 73-up Darts had a Toucan beak point to them...
Re: Dart hood same as..... [Re: da50r] #1473518
07/24/13 11:25 PM
07/24/13 11:25 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
HA!
The OP is actually correct. BOTH cars used the same hood. BOTH cars had header panels that spanned from fender to fender. The front edge of the hood didn't extend to the grille on either car.
Re: Dart hood same as..... [Re: Kern Dog] #1473519
07/24/13 11:29 PM
07/24/13 11:29 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
HA!
Are they exactly the same?
Re: Dart hood same as..... [Re: Kern Dog] #1473520
07/24/13 11:31 PM
07/24/13 11:31 PM
God's Country Maryland
GODSCOUNTRY340 Offline
There is one difference, if you chose the fender mounted turn signal indicators, they were on the top of the fenders of the Dart and on the hood of the Barracuda.
Re: Dart hood same as..... [Re: da50r] #1473521
07/24/13 11:32 PM
07/24/13 11:32 PM
USA
rftroy Offline
rftroy  Offline
USA
The 69 Barracuda hood has hinges with round bolt holes, and sliding nut plates in the hood to allow for adjustment.
Some of the later Dart hoods have fixed nuts welded into the hood, and large square holes with rounded off corners in the hinges to allow for adjustment.
You will need the correct hinges to match with the hood.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Dart hood same as..... [Re: rftroy] #1473522
07/24/13 11:34 PM
07/24/13 11:34 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The outer skin/stamping is the same. When the hood is closed, they look identical.
Re: Dart hood same as..... [Re: Kern Dog] #1473523
07/24/13 11:37 PM
07/24/13 11:37 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
Cool Trivia
Re: Dart hood same as..... [Re: da50r] #1473524
07/24/13 11:47 PM
07/24/13 11:47 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
That is one of the few single parts that interchange across the A body line, from Dodge to Plymouth.
For as much as they look alike, aside from this hood, no single outer body part interchanges besides this.
The 67-69 and 73-76 Dart fenders also used the same outer stamping. The headlight mounting and side marker designs were the only differences.
The 67-76 Valiant/Duster used the same outer stamping though, making them the longest single CAR fender design in Chrysler history. Once again, this is not accounting for the side marker design.
Re: Dart hood same as..... [Re: GODSCOUNTRY340] #1473525
07/24/13 11:47 PM
07/24/13 11:47 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Cool so you could have a car with DUAL hood/fender turn indicators... Sweet!
Or hook up the second set to turn on when the headlights are on... Never forget to shut them off and drain the battery after you leave for work in the dark, and get there after sun up...
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dart hood same as..... [Re: Kern Dog] #1473526
07/25/13 02:27 PM
07/25/13 02:27 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
'67-'69 Valiant 2 doors and '67-'68 Dart 2 door sedans use the same doors. -pauly
Re: Dart hood same as..... [Re: pauly v.100] #1473527
07/25/13 02:35 PM
07/25/13 02:35 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Man I must have lost my noggin! I totally forgot about the doors on these cars!
Yes, there is a wide interchange with the doors. dang... I was feeling pretty good about my skills for a moment there.
Re: Dart hood same as..... [Re: Kern Dog] #1473528
07/25/13 04:05 PM
07/25/13 04:05 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
and the doors and trunk lids...duster, demon, dart sport. 70-72 and 73-76.
the only difference in the dart sport hood and 69 barracuda (other than the hinge mounting) is the crumple zone structure.
Re: Dart hood same as..... [Re: nomore65BelvJim] #1473529
07/25/13 10:59 PM
07/25/13 10:59 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Until you try to put 75 door glass in a 73, almost every year was different. I know plenty of other differences in fenders, doors, and hoods. You guys have just scratched the surface, they may outwardly look the same, but...
JB Rhinehart, Realist
A-Body's RULE!
Re: Dart hood same as..... [Re: Rhinodart] #1473530
07/26/13 12:12 AM
07/26/13 12:12 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Door glass....
Rhino is right. The regulators changed frequently. The mounting holes in the windows seemed to move around alot year to year.
