A/C discharge hose 69 B-body w/ 440 #1473360
07/24/13 01:30 PM
07/24/13 01:30 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Trying to figure out what an original discharge hose for a 69 b-body looks like.
the attached picture is of a hose that was on my car. the rubber hose failed and was replaced by splicing in a new rubber section. my question is whether or not the end of the hose on the muffler end (closest to the compressor)has a compression type fitting or if the rubber hose was directly crimped to the muffler outlet?
I've seen both variations and don't know what was there originally....
Re: A/C discharge hose 69 B-body w/ 440 [Re: BTTG] #1473361
07/24/13 01:32 PM
07/24/13 01:32 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
or is this as it was originally with the rubber hose crimped directly to the muffler outlet... not a compression type fitting...
Re: A/C discharge hose 69 B-body w/ 440 [Re: BTTG] #1473362
07/24/13 01:36 PM
07/24/13 01:36 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This one is correct (crimped to the muffler)
Re: A/C discharge hose 69 B-body w/ 440 [Re: BTTG] #1473363
07/24/13 03:41 PM
07/24/13 03:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The correct one, fyi, not an easy hose to find I might add,,,, It's 1969 B body ,,,big block only
1967-68 is similar but has a seperate muffler section
Re: A/C discharge hose 69 B-body w/ 440 [Re: gtx6970] #1473364
07/24/13 04:41 PM
07/24/13 04:41 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I have an old school A/C service guy locally that has made me new pipe/hose assy's using the old as a road map. He has the parts and tools to swage up the hose to the existing baffle and to the new pipe. He made all the hard lines I needed for a '68 and '69 BB cars.
If you can find a guy like that locally you may be in luck. PM me if you need any more help.
Re: A/C discharge hose 69 B-body w/ 440 [Re: BTTG] #1473365
07/24/13 07:20 PM
07/24/13 07:20 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
That is a good lookin hose!
As others said correct for 69 BB cars
PS---wheres your battery tray & hold down?
1MYTGTX
