Re: A/C discharge hose 69 B-body w/ 440
[Re: BTTG]
#1473362
07/24/13 01:36 PM
07/24/13 01:36 PM
Posts: 21,521 N.E. OHIO, USA
A12
N.E. OHIO, USA
or is this as it was originally with the rubber hose crimped directly to the muffler outlet...
This one is correct (crimped to the muffler)
[Re: BTTG]
#1473363
07/24/13 03:41 PM
07/24/13 03:41 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
or is this as it was originally with the rubber hose crimped directly to the muffler outlet... not a compression type fitting...
The correct one, fyi, not an easy hose to find I might add,,,, It's 1969 B body ,,,big block only
1967-68 is similar but has a seperate muffler section
