Re: Not much quicker with 410" stroker??
[Re: Randy..]
#1473038
07/23/13 11:25 PM
07/23/13 11:25 PM
Posts: 437 south central pa
bdaz smblk
south central pa
What for converter is in it?
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: vern73]
#1473039
07/23/13 11:26 PM
07/23/13 11:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With a stroker you need more filling ablity... if your cam was smallish for the 360 then its REALLY small for the 410... that goes for the heads and the headers and carb...you could easily be way past peak power
[Re: cudadoug]
#1473041
07/24/13 07:55 AM
07/24/13 07:55 AM
Posts: 1,532 off the grid
340B5
off the grid
It's a whole new animal now. It's gonna take a lot of tuning.
Experiment and keep track in a logbook.
Yeah, it's got a smallblock.
[Re: vern73]
#1473042
07/24/13 12:44 PM
07/24/13 12:44 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I put a 4" forged crank in my 360, left everything else the same, except for a 4.10 gear now instead of 4.30's. The 4.30 was going to wind it too hard. It crosses at 6550 now. This is in a Dart which I bracket race. It now runs 10.80 at 121.5mph and with the 360 it would be 11.0 at 119, so I feel disappointed with all the money spent for so little et improvement. I wonder if I expected too much? What do you think?
Tell us about the combination you have, intake, cam, compression, etc. etc. As a rule, when you add cubic inches you need to improve head flow, intake flow, camshaft size, header size, etc. etc. If all you did was put the bigger crank in it, you got pretty much what I would expect, a low rpm torque motor that's done making power pretty early in the rpm range.
machine shop owner and engine builder
[Re: Performance Only]
#1473043
07/24/13 12:48 PM
07/24/13 12:48 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Yep, way back when I had a long conversation with Ken Hensley on the phone asking him how much difference a 4 inch crank would make over a stock stroke 340 with all else being the same with the eddie heads I was working with, and I remember him stating probably about 3 tenths is all you will see
#1473044
07/24/13 12:59 PM
07/24/13 12:59 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
W/o adding flow, you aren't gonna see much...you'll just drop the powerband down and add some torque.
Good friend of mine had a backhalved Daytona w/ a 440 in it...stock iron 346 casting heads, tight converter. He wanted to go fast so we turned it into a 499 (everything else the same)...it only ran .15 sec quicker in the 1/8. All the gain was in the 60'. Got a good converter for it...dropped .5 sec. Got some Indy SR heads...dropped another .5 sec. Would have gone a bunch faster, but sold it before we did any tuning after the new heads went on.
[Re: vern73]
#1473045
07/24/13 01:11 PM
07/24/13 01:11 PM
Posts: 2,177 ill
dennismopar73
ill
So, really,,you are disappointed? you changed the whole dynamics of the motor and gear, it picks up,, and your disappointed?? I would have kept the 430s in, changed cam, shift points, bigger carb, but , you have nothing to be disappointed about at all!
[Re: vern73]
#1473049
07/24/13 11:29 PM
07/24/13 11:29 PM
Performance Only
To follow up, everything else stayed the same. The cam is 252I-248E at .050 with .555I, .525E lift, Heads are mildly ported Edelbrocks, AirGap intake, 750cfm Quick Fuel carb, 727 trans. with PTC 8inch converter, flashes to 5200. Car is about 3100 lbs. without me. That's the combo pretty much. And I didn't know quite what to expect e.t. wise so that's why I'm asking. It has been to the track 3 times, but the weather has been really hot.
Lots of potential there with some changes. What is the current compression ratio and what is the current cranking compression? Mildly ported edelbrocks will hold that engine back considerably. the cam isn't even close to what I'd normally run in a combo like that, but in the end you really have to look at the entire combo and have everything working well together. From what I see you're intentions were good but by not adapting to the change in engine size you're just holding the engine back from its true potential. I would guess maybe that was done for budgetary concerns? You could very easily pick up considerable power but you would need too almost tear it apart and start again. More flow in the heads, better cam and larger carb would really wake it up. It's just my opinion, but in general, edelbrock heads even fully ported are still small for that size engine, but as I said, more port work can make a huge difference. How much of a gain would you like to see?
[Re: viperblue72]
#1473052
07/26/13 09:16 AM
07/26/13 09:16 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
I think that combo is running strong in the heat. When cool weather comes you'll pick up that .10 to.15 maybe even .2 You just need more atmosphere What do you have the timing set at?
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: viperblue72]
#1473053
07/26/13 09:18 AM
07/26/13 09:18 AM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I kinda did the same thing with my 440...stock unported iron 906 heads, 530 lift roller cam ,performer intake and holly 750..went 12.5 @ 109 mph..just put a 4.125 stroker kit ....used all the same parts and went 11.72 @ 114 mph..and changed gears from 3;91 to 3;55
[Re: dynamite]
#1473054
07/26/13 11:18 AM
07/26/13 11:18 AM
B3422W5
Portage,michigan
Actually runs real well for what you have going on I think you went in the right direction with the convertor, probably still even at 5200 flash its a bit too high with what your combination is, around 4900-5000 would be more optimal, imo. Definitely leaving something on the table with the cam you have, should have more lift and 10 degrees more duration. I agree a bigger carb would also show a gain, 950hp would probably be a good upgrade. Unsure why after tightening up the convertor you lost 3 hundreds, perhaps worse air, track prep or who knows what, but you went in the correct direction. I ran almost the same combo as you a while back( 3450 race weight,bench seat column shift, 727, 4.10 gear, weiand excellerator, 416, mild ported eddies( 275 peak@600) 260/266 598/623 lift flat tappet, 1025 race demon 4150 carb, tti 1 5/8 to 1 3/4 step headers and mufflers, 8 inch convertor flashed 4900), just a tiny bit more compression...went 10.74 at 124, 1.44 60 foot. Mine laid over big time the last 150 foot of track or so.
