Not much quicker with 410" stroker?? #1473035
07/23/13 11:06 PM
07/23/13 11:06 PM
Kentucky
V
vern73 Offline OP
vern73  Offline OP
V
Kentucky
I put a 4" forged crank in my 360, left everything else the same, except for a 4.10 gear now instead of 4.30's. The 4.30 was going to wind it too hard. It crosses at 6550 now. This is in a Dart which I bracket race. It now runs 10.80 at 121.5mph and with the 360 it would be 11.0 at 119, so I feel disappointed with all the money spent for so little et improvement. I wonder if I expected too much? What do you think?
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473036
07/23/13 11:08 PM
07/23/13 11:08 PM
WA
JD Dart Offline
JD Dart  Offline
WA
What heads? what cam? what headers? Did you change them?
Re: Not much quicker with 410" stroker?? [Re: JD Dart] #1473037
07/23/13 11:12 PM
07/23/13 11:12 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
faster with less gear and lower rpm, bout right to me.
Re: Not much quicker with 410" stroker?? [Re: Randy..] #1473038
07/23/13 11:25 PM
07/23/13 11:25 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
What for converter is in it?
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473039
07/23/13 11:26 PM
07/23/13 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With a stroker you need more filling ablity... if
your cam was smallish for the 360 then its REALLY small
for the 410... that goes for the heads and the headers
and carb...you could easily be way past peak power
Re: Not much quicker with 410" stroker?? [Re: MR_P_BODY] #1473040
07/24/13 12:08 AM
07/24/13 12:08 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
MANY things at play here. We gained 9/10's and 7 mph going from a 340 to a 416 (11.05/121 best to 10.14/128) best BUT...
Lighter bob weight
Better heads (same intake and carb)
Better cam
Converter adjusted for new motor
2.77 low gear removed for 2.45
4.56 (still to low) rather than 5.12
Changed from a 1 5/8" header to 1 3/4"...same collector size.
Oh, and added muffs
So tell us more about the comparable motor/converter combos...
Re: Not much quicker with 410" stroker?? [Re: cudadoug] #1473041
07/24/13 07:55 AM
07/24/13 07:55 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
It's a whole new animal now. It's gonna take a lot of tuning.
Experiment and keep track in a logbook.
Yeah, it's got a smallblock.
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473042
07/24/13 12:44 PM
07/24/13 12:44 PM
Delray beach, Florida
P
Performance Only Offline
P
Tell us about the combination you have, intake, cam, compression, etc. etc. As a rule, when you add cubic inches you need to improve head flow, intake flow, camshaft size, header size, etc. etc.
If all you did was put the bigger crank in it, you got pretty much what I would expect, a low rpm torque motor that's done making power pretty early in the rpm range.
machine shop owner and engine builder
Re: Not much quicker with 410" stroker?? [Re: Performance Only] #1473043
07/24/13 12:48 PM
07/24/13 12:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep, way back when I had a long conversation with Ken Hensley on the phone asking him how much difference a 4 inch crank would make over a stock stroke 340 with all else being the same with the eddie heads I was working with, and I remember him stating probably about 3 tenths is all you will see
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Not much quicker with 410" stroker?? [Re: Performance Only] #1473044
07/24/13 12:59 PM
07/24/13 12:59 PM
an8sec70cuda Offline
W/o adding flow, you aren't gonna see much...you'll just drop the powerband down and add some torque.
Good friend of mine had a backhalved Daytona w/ a 440 in it...stock iron 346 casting heads, tight converter. He wanted to go fast so we turned it into a 499 (everything else the same)...it only ran .15 sec quicker in the 1/8. All the gain was in the 60'.
Got a good converter for it...dropped .5 sec.
Got some Indy SR heads...dropped another .5 sec. Would have gone a bunch faster, but sold it before we did any tuning after the new heads went on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473045
07/24/13 01:11 PM
07/24/13 01:11 PM
ill
dennismopar73 Offline
ill
So, really,,you are disappointed?
you changed the whole dynamics of the motor and gear, it picks up,, and your disappointed??
I would have kept the 430s in, changed cam, shift points, bigger carb, but , you have nothing to be disappointed about at all!
Re: Not much quicker with 410" stroker?? [Re: dennismopar73] #1473046
07/24/13 03:23 PM
07/24/13 03:23 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
That is still a 30 horsepower gain to gain 2.5 mph.
Have you only had your stroker out 1 time?
2 tenths doesn't sound like a lot, but it takes more than people think to gain that when already running bottom 11s.
Yes I think you expected too much when changing nothing else. You have a much better base to build from now. It's going to be much easier to make more power with changes. Bigger carb, camshaft for start. And you will be able to keep the rev range happy while doing it.
Re: Not much quicker with 410" stroker?? [Re: viperblue72] #1473047
07/24/13 10:32 PM
07/24/13 10:32 PM
Kentucky
V
vern73 Offline OP
vern73  Offline OP
V
Kentucky
To follow up, everything else stayed the same. The cam is 252I-248E at .050 with .555I, .525E lift, Heads are mildly ported Edelbrocks, AirGap intake, 750cfm Quick Fuel carb, 727 trans. with PTC 8inch converter, flashes to 5200. Car is about 3100 lbs. without me. That's the combo pretty much. And I didn't know quite what to expect e.t. wise so that's why I'm asking. It has been to the track 3 times, but the weather has been really hot.
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473048
07/24/13 10:39 PM
07/24/13 10:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Did you rejet your carb?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473049
07/24/13 11:29 PM
07/24/13 11:29 PM
P
P
Lots of potential there with some changes. What is the current compression ratio and what is the current cranking compression? Mildly ported edelbrocks will hold that engine back considerably. the cam isn't even close to what I'd normally run in a combo like that, but in the end you really have to look at the entire combo and have everything working well together. From what I see you're intentions were good but by not adapting to the change in engine size you're just holding the engine back from its true potential. I would guess maybe that was done for budgetary concerns? You could very easily pick up considerable power but you would need too almost tear it apart and start again. More flow in the heads, better cam and larger carb would really wake it up. It's just my opinion, but in general, edelbrock heads even fully ported are still small for that size engine, but as I said, more port work can make a huge difference.
How much of a gain would you like to see?
Re: Not much quicker with 410" stroker?? [Re: Performance Only] #1473050
07/26/13 08:16 AM
07/26/13 08:16 AM
Kentucky
V
vern73 Offline OP
vern73  Offline OP
V
Kentucky
As far as the gain I'd like to see, probably a tenth to tenth and a half better than now. The comp. ratio is about 10.9 to 1 and cranking compression is 180. And yes I reused the heads and cam for budget reasons. Maybe could work on that later. The converter was initially flashing to 5600 with this motor so I had it tightened to 5200 or so and lost a little et. I thought the 5600 was already past the torque peak and tightening would help but it went from 10.78 to 10.81 so lost a little. Surprised me. The cam is advanced 4 degrees to 104, PTC converter guy said I had plenty of low end torque and probably should put it straight up. What do you think?
Re: Not much quicker with 410" stroker?? [Re: vern73] #1473051
07/26/13 09:05 AM
07/26/13 09:05 AM
V
viperblue72 Offline
viperblue72  Offline
V
For running mild edelbrocks and a mild solid camshaft, I think your combo is running really good.
But to make that stroker not run like a tractor, you will have to open those heads up. That's all there is too it. Even a bigger camshaft isn't going to help much until you open the heads up more, or go with a bigger head altogether.
Re: Not much quicker with 410" stroker?? [Re: viperblue72] #1473052
07/26/13 09:16 AM
07/26/13 09:16 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I think that combo is running strong in the heat. When cool weather comes you'll pick up that .10 to.15 maybe even .2 You just need more atmosphere
What do you have the timing set at?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Not much quicker with 410" stroker?? [Re: viperblue72] #1473053
07/26/13 09:18 AM
07/26/13 09:18 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I kinda did the same thing with my 440...stock unported iron 906 heads, 530 lift roller cam ,performer intake and holly 750..went 12.5 @ 109 mph..just put a 4.125 stroker kit ....used all the same parts and went 11.72 @ 114 mph..and changed gears from 3;91 to 3;55
Re: Not much quicker with 410" stroker?? [Re: dynamite] #1473054
07/26/13 11:18 AM
07/26/13 11:18 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Actually runs real well for what you have going on
I think you went in the right direction with the convertor, probably still even at 5200 flash its a bit too high with what your combination is, around 4900-5000 would be more optimal, imo.
Definitely leaving something on the table with the cam you have, should have more lift and 10 degrees more duration.
I agree a bigger carb would also show a gain, 950hp would probably be a good upgrade.
Unsure why after tightening up the convertor you lost 3 hundreds, perhaps worse air, track prep or who knows what, but you went in the correct direction.
I ran almost the same combo as you a while back( 3450 race weight,bench seat column shift, 727, 4.10 gear, weiand excellerator, 416, mild ported eddies( 275 peak@600) 260/266 598/623 lift flat tappet, 1025 race demon 4150 carb, tti 1 5/8 to 1 3/4 step headers and mufflers, 8 inch convertor flashed 4900), just a tiny bit more compression...went 10.74 at 124, 1.44 60 foot. Mine laid over big time the last 150 foot of track or so.
1.41 best 60 foot
6.56 at 104.17
