Head Gasket replacement needed !! #1472331
07/22/13 08:48 PM
07/22/13 08:48 PM
PA - Phila
71GRANCOUPE Offline OP
PA - Phila
I'd like to think I could handle this but I will leave it to a professional. How much should it cost to replace a head gasket on a Dodge Shadow? The car itself is in great condition but it may not be worth saving vs buying another car -- it would be my daughter's first car. Thanks for the help.
68 Barracuda Conv
Re: Head Gasket replacement needed !! [Re: 71GRANCOUPE] #1472332
07/22/13 09:37 PM
07/22/13 09:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The cost will vary if the head has damage, as in warped ect.. Id do a T belt and water pump install also..
I am truckless..
Re: Head Gasket replacement needed !! [Re: 71GRANCOUPE] #1472333
07/23/13 01:53 PM
07/23/13 01:53 PM
PA
70Duster Offline
70Duster  Offline
PA
You'll probably be further ahead just swapping the engine with a known good one.
Re: Head Gasket replacement needed !! [Re: 70Duster] #1472334
07/23/13 01:55 PM
07/23/13 01:55 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Problem with that is the new engine would probably need a head gasket done too
I've probably done 20-30 headgaskets on these cars over the years and they are one of the easier ones to change at least to me. Just don't use a cheap headgasket and they will last.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Head Gasket replacement needed !! [Re: 71GRANCOUPE] #1472335
07/23/13 03:24 PM
07/23/13 03:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
chiltons time will be in the approx 5 to 6 hour range. In my shop that would be a $300-$400 dollar job
To be honest it can be done in about 3 hours if you know what your doing.
Probably one of the easiest cars to work on, as techs we didn't know how well we had it back then
as far as finding a good engine? good luck with that . these cars and there parts are not the easiest to find in todays market
