Head Gasket replacement needed !!
#1472331
07/22/13 08:48 PM
07/22/13 08:48 PM
Posts: 276 PA - Phila
71GRANCOUPE
PA - Phila
I'd like to think I could handle this but I will leave it to a professional. How much should it cost to replace a head gasket on a Dodge Shadow? The car itself is in great condition but it may not be worth saving vs buying another car -- it would be my daughter's first car. Thanks for the help.
68 Barracuda Conv
Re: Head Gasket replacement needed !!
[Re: 71GRANCOUPE]
#1472332
07/22/13 09:37 PM
07/22/13 09:37 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The cost will vary if the head has damage, as in warped ect.. Id do a T belt and water pump install also..
I am truckless..
[Re: 70Duster]
#1472334
07/23/13 01:55 PM
07/23/13 01:55 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Problem with that is the new engine would probably need a head gasket done too I've probably done 20-30 headgaskets on these cars over the years and they are one of the easier ones to change at least to me. Just don't use a cheap headgasket and they will last.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
