1st stroker kit went smooth
2nd stroker kit slight delay
Rod says he checks all orders before going out
Well the custom pistons are packaged by the piston company along with the pins and rings,in ONE box
Rod called and said while checking them the rings were wrong.
will be a one week delay
That is fine by me,cause, I wouldn't have been very happy, to stop in the middle of a build, and wait on rings.
better the HE found the problem,than me,
when I went to fit the rings on the pistons
Thanks Rod..
p.s.
all crank and rod specs right on
Also noticed that the cranks are drilled and finished for a standard trans bushing.
