Re: How to ID where a crate Hemi was MFG [Re: JohnRR] #1470108
07/24/13 05:07 PM
07/24/13 05:07 PM
Omaha Nebraska
Brian_wo Offline OP
Brian_wo  Offline OP
Omaha Nebraska
On the front side of the engine nothing,I will have to pull it away from the wall to check the backside.
who is that guy?
Re: How to ID where a crate Hemi was MFG [Re: Brian_wo] #1470109
07/24/13 11:55 PM
07/24/13 11:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I looked at my hemi tonight , NOTHING on the ID pad , the only ID is the sticker with bar code on the bellhousing flange next to the do not bore over 4.340 sticker .
Brian if that is not an Arrow engine then it's Cummins and was built during the time they were WORSE than the junk I bought in '05 ...
Re: How to ID where a crate Hemi was MFG [Re: JohnRR] #1470110
07/25/13 01:43 AM
07/25/13 01:43 AM
Omaha Nebraska
Brian_wo Offline OP
Brian_wo  Offline OP
Omaha Nebraska
Its not an Arrow engine,confirmed by them
Weird thing is the guy I got it from sold two others he was sure were cummins motors and I guess they are running problem free.
I know my luck so it will be dropped off at my machinest to be gone through.
who is that guy?
Re: How to ID where a crate Hemi was MFG [Re: JohnRR] #1470111
07/25/13 02:00 AM
07/25/13 02:00 AM
Petaluma, CA
JimDiesel Offline
JimDiesel  Offline
Petaluma, CA
My 472 was purchased from Summit in June 2001.
the pad is stamped with:
472
H1699
242
I have no idea who made it.
68 Road Runner
67 Coronet
Re: How to ID where a crate Hemi was MFG [Re: Brian_wo] #1470112
07/25/13 07:45 AM
07/25/13 07:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Brian easy to check a couple of things , pull the intkae and a valve cover. grab a spring on a closed valve , if you can move the spring around then that will tell you the needs need to be gone thru and look in the valley for any debris.
