AX15 vs A500 #1469744
07/18/13 01:46 PM
07/18/13 01:46 PM
Dreaming of Idaho
U
unlucky68 Offline OP
U
Dreaming of Idaho
Hello, looking at a Dakota Convertibles and just wondering how hard is the AX15 to shift and how does it compare to the A500 for driving. I found a 4x4 with the AX15 and just want to know if I the clutch is "hard" to engage if that makes sense. I know the newer manuals are fairly easy to press in on the clutch. Also, would the AX15 do better on fuel economy behind a V6 because of the lower OD ratio of 0.84 vs 0.69 for the A500. Thank you in advance.
Re: AX15 vs A500 [Re: unlucky68] #1469745
07/18/13 02:05 PM
07/18/13 02:05 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
The AX15 is a pretty easy trans to shift, as far as light duty truck transmissions go. If you don't beat it, it will last nearly indefinitely behind a V6.
It will also get much better mileage than an A500, since it is a manual trans, as opposed to an automatic.
