Dana 60, B body, New Leafs...do I need shims?
#1469660
07/18/13 04:09 AM
07/18/13 04:09 AM
Posts: 711 California
BigDaddy440
California
From what I understand, shims between the leaf springs and the housing assembly are to adjust pinion angle. Obviously measuring this is the best thing to do. But my Dana 60 is rebuilt and I'm getting close to install time. So...
Question:
Is there a basic B body "rule of thumb" with shims? Should I just set the car up without shims and measure the pinion angle later? Whats recommended? If not, what shims should I use to get it "ballpark" close for an initial set up?
-Dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Dana 60, B body, New Leafs...do I need shims?
[Re: BigDaddy440]
#1469661
07/18/13 05:26 AM
07/18/13 05:26 AM
Posts: 2,141 junction city oregon
viperblue72
I would measure your spring perches in relation to your pinion. If they are 90 degrees different then you'll likely need to shim it downward. If it's more than 90 then somebody already accounted for this. I have heard anywhere from 3 to 5 degrees down.
[Re: Clanton]
#1469663
07/18/13 04:19 PM
07/18/13 04:19 PM
Posts: 2,665 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Get the car put together first. Then you can measure the pinion angle. The Mopar chassis book will tell you the desired number. Install proper shim. It's easy.
2011 Drag Pak Challenger
[Re: rickseeman]
#1469664
07/18/13 04:38 PM
07/18/13 04:38 PM
Posts: 139 Motor City
Noodle
Motor City
bolt it all up , measure angle , mark the spring perches ( front back & middle ) the pull all apart and weld the perches on , or you can tack them if you got a mig when it's all bolted up! No need to waste money on shims !!
Just another DH!
