Re: .1964 SAVOY questions
[Re: runner12]
#1469482
07/17/13 09:46 PM
07/17/13 09:46 PM
Posts: 20,797 A collage of whims
topside
A collage of whims
Sheet metal: 4-speed humps, floor pieces and IIRC full floors (Pass compartment). Also crank & door handles. Interior: Some seat material, carpet, windlace & gaskets, maybe the SS-style side trim panels. Trim: tail lamp lenses Underhood: detailing items like decals and some seals, Maxie intake & exhaust manifolds and full exhaust. Some items interchange '63-'65 plus less from '62. Note that the cowl, dash, roof & ft door window framing differs from the '62-'63 cars. You'll get to know Kramer's, restorationspecialties.com, and Joe Suchy (major '64 guy).
[Re: topside]
#1469487
07/18/13 08:27 AM
07/18/13 08:27 AM
Posts: 255 Washington, Pa
runner12
Washington, Pa
WOW!! great info ,I will put it to good use . Thanks what about those tire sizes and offset on the rim ? any idea ?
[Re: runner12]
#1469488
07/18/13 09:17 AM
07/18/13 09:17 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
64 65 used a ball and trunion drive shaft.they also used the speedo gear thats one piece and clips on the cable.My 65s still works great.66 up 4 speed you change speedo gear and cable along with slip yoke drive shaft.Disc conversion find a 73 up A body or Diplomat,Aspen etc,They have taller spindles but seem to work better.You should have the old style rear also.Axles need changed.65 to 70 B body is a direct swap or Dr Diff has a conversion kit.If its was a /6 car you need V8 K member or the conversion mounts.Rocky
Chrysler Firepower
[Re: Polarapete]
#1469491
07/18/13 07:56 PM
07/18/13 07:56 PM
runner12
Washington, Pa
I was checking out cars in the show feild at carlisle and found one that was not tubbed had 285/70/ 15 looked good filled the wheel well but could of been a little wider?? I might just call passion or brewers and just get a complet set up for the 4 spd instead of old stuff. Thanks Nick
[Re: runner12]
#1469492
07/18/13 11:11 PM
07/18/13 11:11 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
We've run 285/70's for over 20 years on our '64 Plymouth. Stock spring location and no minitubs...'69 B-body Dana.
If you are interested in running Calvert Racing monoleafs, let me know. I can give you the proper part #'s. It took Travis @ Calvert and I 3 different attempts at the rear segments to get the proper ride height.
[Re: runner12]
#1469494
07/19/13 08:09 PM
07/19/13 08:09 PM
therocks
Niles , Ohio
SS springs require special hangers.Dont use the MP hangers.They are the wrong length.64 has a 21 inch front segment.SS are 20 inch.A member here makes the correct ones.Mancini sells them and I think he does also.Rocky
Chrysler Firepower
