would oil on CPS cause random signal loss #1468536
07/15/13 09:54 PM
07/15/13 09:54 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Re: would oil on CPS cause random signal loss [Re: hp383] #1468537
07/15/13 10:04 PM
07/15/13 10:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
cps ?
Re: would oil on CPS cause random signal loss [Re: JohnRR] #1468538
07/15/13 10:06 PM
07/15/13 10:06 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
crank position sensor. shouldn't cause an issue.
Re: would oil on CPS cause random signal loss [Re: MPerry] #1468539
07/15/13 10:07 PM
07/15/13 10:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what is the acronym for camshaft position sensor ?
either way oil on them would be a problem ..
in them ???
Re: would oil on CPS cause random signal loss [Re: JohnRR] #1468540
07/15/13 10:14 PM
07/15/13 10:14 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
oil won't break the magnetic signal. Many vehicles have the sensors position in the block where oil is. Cam acronym is cmp
Re: would oil on CPS cause random signal loss [Re: MPerry] #1468541
07/15/13 11:50 PM
07/15/13 11:50 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Thanks for the advice. I didnt think some oil (not a great deal, but its more than a slight ammount).
I had the CPS replaced 4 months ago with the new trans as a precaution. They told me I was lucky to be driving as the original CPS was cracked!
Said they had never seen one run with a cracked.
The one put in with the trans was a Rockauto cheap brand. I replaced with the only one offered by Oreilly (Not sure its any better, but it did cost about double).
I figured a quick sensor change to see if that cures my ills was a good plan before ripping into a timing chain replacement.
We'll see if it stops acting up over the next week.
On a side note, are there any bench tests for a CPS to verify its working correctly?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: would oil on CPS cause random signal loss [Re: hp383] #1468542
07/16/13 12:37 AM
07/16/13 12:37 AM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
YES!!!!! It will if its on the wiring going into it. Or it is cracked on the block side. It causes Resistance in the wiring.Ive changed hundreds for this issue at the dealer.
Re: would oil on CPS cause random signal loss [Re: bdusted440] #1468543
07/16/13 02:09 AM
07/16/13 02:09 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
The oil on mine was on the "inside the bellhousing side" probably the tell tale sign of the beginnings of a rear main leak. Time to run a thicker, high mile formulated oil to swell things up. The wires and plug were [Edited by Moparts - Family Friendly Site - Keep it clean] and span.
Just, for lack of better word, a dribble down one side of the part that sticks inside the bellhousing.
Edit: Apparently the Moparts filter felt I was making a racial slur towards those of Mexican heritage.
