Re: piston selection help? [Re: Dodgem] #1467889
07/16/13 09:51 AM
07/16/13 09:51 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
I'm just waiting to hear the rest of the story.
Re: piston selection help? [Re: Dodgem] #1467890
07/16/13 02:12 PM
07/16/13 02:12 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
at first it was excesive blowby then i dropped two valves,pulled thru the retainers now its two cracked pistons ill try and get pics later today
Re: piston selection help? [Re: moparsquid] #1467891
07/16/13 06:51 PM
07/16/13 06:51 PM
Southern Indiana
R/T Lee Offline
R/T Lee  Offline
Southern Indiana
Wow I think I would go right back to who u bought it from, And do a custom stroked out kit on his head!! I wouldn't do anything else to it, and try like hell to get your money back!! I hate hearing stories like this.
NO!! It's not a Nova...
72' Demon 340-727-8 3/4 3.55
69' Charger 440-727-8 3/4
78 Powerwagon 318-727
99' Dakota R/T 5.9
74' Scamp (project)
96' Cherokee 4.0 4x4
Re: piston selection help? [Re: R/T Lee] #1467892
07/16/13 09:17 PM
07/16/13 09:17 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
I agree and here's the kicker ,he's a long time friend . I do plan to confront him but I know what the results will be.....stay tuned for future events
Re: piston selection help? [Re: moparsquid] #1467893
07/17/13 09:07 AM
07/17/13 09:07 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I wouldn't CONFRONT him , I would go there and TALK to him and find out what he is going to do to make it right .
Re: piston selection help? [Re: JohnRR] #1467894
07/17/13 12:18 PM
07/17/13 12:18 PM
dogdays Offline
dogdays  Offline
Gotta agree with JohnRR, the best approach is to park your emotions at the door. Be as calm as possible, say things like, "We've got a problem and I wondering what you are going to do to make it right."
Also, and this is important, know what you want and can reasonably get as a remedy. You for sure need new pistons, as some have cracked oil ring lands by your description.
You need to find out how the engine was assembled. Were the rods gone through with new rod bolts? Was it balanced? Stuff like that. Know some ballpark prices for parts, like you'd find in a 440Source catalog.
And keep the personal invective out of it. He (and you) may well know that he's a lyin' piece of s@#$ but you don't need to tell him. That won't get the job any closer to done.
I know how hard this is, I haven't been the best at following my own advice. But it seems that when I do, it turns out better.
R.
Re: piston selection help? [Re: moparsquid] #1467895
07/17/13 01:44 PM
07/17/13 01:44 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If they are edelbrock victor heads the springs, keepers and retainers have to be purchased and installed later. The keepers pulling through the retainer would seem indicative of Cheap Chinese parts and or springs going to coil bind and that causing the damage.
Your lucky a valve never dropped or snapped the stem off and thus dropping anyways.
I think you have lots of checking and work to do to make things right you may as well start with premium rods and pistons hone balance and go from there.
Re: piston selection help? [Re: Dodgem] #1467896
07/17/13 07:34 PM
07/17/13 07:34 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I think I would just plain ask him for my money back, and he can have his engine back.
It's Swifty! Swifty, you toad sucker!
Re: piston selection help? [Re: zrxkawboy] #1467897
07/17/13 08:55 PM
07/17/13 08:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I suspect that there is a lot more to this story, and drawing any conclusions on a small portion of half of the story is simply silly.
Enough statements by the OP have me scratching my head.
To the OP, your lowest cost option is to by more 400 pistons.
Re: piston selection help? [Re: Dodgem] #1467898
07/18/13 11:21 PM
07/18/13 11:21 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
here are some pics ,I was shocked at the bad bearings
Re: piston selection help? [Re: moparsquid] #1467899
07/18/13 11:22 PM
07/18/13 11:22 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
another
Re: piston selection help? [Re: moparsquid] #1467900
07/18/13 11:24 PM
07/18/13 11:24 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
more
Re: piston selection help? [Re: JohnRR] #1467901
07/18/13 11:27 PM
07/18/13 11:27 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
when i said confront i didnt mean in an agressive manner i ment bring it to his attention to let him know what has transpired
Re: piston selection help? [Re: moparsquid] #1467902
07/19/13 09:11 AM
07/19/13 09:11 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did you check the rings for butting?
Re: piston selection help? [Re: Dodgem] #1467903
07/19/13 09:47 AM
07/19/13 09:47 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
yes and they seem to be okay as for fit
Re: piston selection help? [Re: moparsquid] #1467904
07/20/13 10:20 AM
07/20/13 10:20 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
.022 to .024 end gap and no shinny on the but ends?
Re: piston selection help? [Re: Dodgem] #1467905
07/20/13 06:06 PM
07/20/13 06:06 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
I havnt checked the end gap with a guage ,just visual ill do that when i get a chance and get pics also,thanks
