will1975 c body rear disc setup swap to B or E #1467783
07/14/13 07:23 PM
07/14/13 07:23 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
Has anyone swapped a rear disc brake setup from a 1975 C body with 9 1/4 rearend to a B or E body with 8 3/4
Re: will1975 c body rear disc setup swap to B or E [Re: Dart6pak] #1467784
07/14/13 07:39 PM
07/14/13 07:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
It can be done but the replacement parts are expensive and hard to find..
I am truckless..
Re: will1975 c body rear disc setup swap to B or E [Re: Dart6pak] #1467785
07/14/13 08:13 PM
07/14/13 08:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually 74/75 disc brake cars were Y body.
Just couldn't help myself !!
Re: will1975 c body rear disc setup swap to B or E [Re: 62maxwgn] #1467786
07/14/13 09:29 PM
07/14/13 09:29 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There was an article YEARS back on this.
Even then, the word was that parts were too hard to find.
Considering that there are now kits, it would be smarter to sell off the stuff if you have it and get something more serviceable...
Re: will1975 c body rear disc setup swap to B or E [Re: RodStRace] #1467787
07/14/13 10:06 PM
07/14/13 10:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The 74/75 Imperial are the only ones that had rear disc brakes,not easy to find.The calipers are not a problem as they are 70 and up A-body,the emergency brakes are a complete assembly with another set of small shoes that goes inside the rotor,extremely hard to find,better to use one of the current upgrades if you don't mind spending the money.
Re: will1975 c body rear disc setup swap to B or E [Re: 62maxwgn] #1467788
07/15/13 04:06 AM
07/15/13 04:06 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought the rear calipers were like slider 73 up calipers. Not the four piston KH 66-72 calipers.
I would think you could find a speciality place to reline the parking brake shoes if necessary (wouldn't think they'd wear much).
I know a couple people that have put them on 8 3/4 rears. You have to use green bearings and only used 4 of the 5 backing plate bolts. Also you machine the caliper adapters to move the caliper over some. I can't remember the amount but something under 3/8".
I though the disk were really hard to come up with??
Re: will1975 c body rear disc setup swap to B or E [Re: autoxcuda] #1467789
07/15/13 08:51 AM
07/15/13 08:51 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I thought...
I thought...
You gotta do this...
You gotta do that...
If..
But...
You're obviously looking for an easy way to put disks on your rear axle. This is not the way to do it. It's a dumb way.
Re: will1975 c body rear disc setup swap to B or E [Re: Commando1] #1467790
07/15/13 09:44 AM
07/15/13 09:44 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is the reason i know how they work !
Re: will1975 c body rear disc setup swap to B or E [Re: Dart6pak] #1467791
07/15/13 01:38 PM
07/15/13 01:38 PM
AndyF Offline
AndyF  Offline
Even I wouldn't do that swap and I have the ability to make just about anything!
If you want rear disc brakes (you probably don't need them but maybe that is beside the point) then get a kit from Cass.
www.doctordiff.com is the address.
Re: will1975 c body rear disc setup swap to B or E [Re: AndyF] #1467792
07/15/13 07:59 PM
07/15/13 07:59 PM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I'll bet ya that by the time you're driving down the road on your new Y-body rear discs you could have just bought a new (better) kit from Doctor Diff instead. I thought about this idea too, many times. It never seemed like the way to go. Maybe if we were in the 70's still...
Re: will1975 c body rear disc setup swap to B or E [Re: Pale_Roader] #1467793
07/15/13 08:57 PM
07/15/13 08:57 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i picked up a set off a 2001 dodge van 1500 9.25---they will bolt onto any other 9.25 8.75 will just have my axle guy index the 5 on 4.5 pattern-----parts are really easy to find--pickapart price $80....bob
Re: will1975 c body rear disc setup swap to B or E [Re: savoy64] #1467794
07/15/13 11:02 PM
07/15/13 11:02 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Are you sure the center register is correct for 8.75" axles (2.81")? I coulda sworn it got much bigger (3.55" comes to mind). If I'm right - how will you pilot (center) it?
Rick
