Re: will1975 c body rear disc setup swap to B or E
[Re: Dart6pak]
#1467785
07/14/13 08:13 PM
07/14/13 08:13 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Has anyone swapped a rear disc brake setup from a 1975 C body with 9 1/4 rearend to a B or E body with 8 3/4
Actually 74/75 disc brake cars were Y body.
Just couldn't help myself !!
[Re: Dart6pak]
#1467791
07/15/13 01:38 PM
07/15/13 01:38 PM
Posts: 30,989 Oregon
AndyF
Even I wouldn't do that swap and I have the ability to make just about anything! If you want rear disc brakes (you probably don't need them but maybe that is beside the point) then get a kit from Cass. www.doctordiff.com is the address.
[Re: savoy64]
#1467794
07/15/13 11:02 PM
07/15/13 11:02 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
i picked up a set off a 2001 dodge van 1500 9.25---they will bolt onto any other 9.25 8.75 will just have my axle guy index the 5 on 4.5 pattern-----parts are really easy to find--pickapart price $80....bob
Are you sure the center register is correct for 8.75" axles (2.81")? I coulda sworn it got much bigger (3.55" comes to mind). If I'm right - how will you pilot (center) it?
Rick
