2002 neon no start #1467720
07/14/13 02:51 PM
07/14/13 02:51 PM
michigan
bighughey Offline OP
michigan
my 2002 neon quits running. will not turn over. replaced ignition swith.(3 of them) i have a no crank,no fuel pump.took apart the under hood fuse box and no broken wires.was checking fuses and everything came on.(fuel pump.inj) car started and ran for 10 minites and shut off.went to check and everything started working again.
Re: 2002 neon no start [Re: bighughey] #1467721
07/14/13 03:12 PM
07/14/13 03:12 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Frist ck all the grounds in the trunk. Then ck the engine harness, they have a habit of getting hot and the insolation will melt on the individual wires.
Re: 2002 neon no start [Re: 71birdJ68] #1467722
07/14/13 03:28 PM
07/14/13 03:28 PM
michigan
michigan
thanks for the info.i have checked every wire i could.i took the fuse box apart in the engine and found nothing coroded.do you think i could be losing ground?
Re: 2002 neon no start [Re: bighughey] #1467723
07/14/13 04:24 PM
07/14/13 04:24 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Check the battery cables.That and Im pretty sure they had a problem with the harness in the rear of the engine.I know we replaced a few at the shop.Rocky
Chrysler Firepower
Re: 2002 neon no start [Re: therocks] #1467724
07/14/13 10:34 PM
07/14/13 10:34 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
positive battery cable known to corrode at the battery terminal..give it a nice yank and see the power come back on
Re: 2002 neon no start [Re: bighughey] #1467725
07/14/13 11:15 PM
07/14/13 11:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The grounds in the trunk are the easiest thing to ck, so start there. I left one of mine loose once, drove me crazy. Everything is controlled by a ground, and they terminate in the trunk were its nice and dry and controlled. At least on the 1st gen Neon. If they are good, then move up front. He's right about the battery cables, but since that is a newer car they should still be good. I didn't have to replace mine till around 440,000. They corrode between the individual strands and loose conductivity.
Re: 2002 neon no start [Re: 71birdJ68] #1467726
07/16/13 01:26 AM
07/16/13 01:26 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Second gen neons have lousy battery cable ends. I've seen way too many with fur growing around them. Not the same cables as first gen cars.
Re: 2002 neon no start [Re: rallye73] #1467727
07/16/13 01:49 AM
07/16/13 01:49 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Didn't know that. When I replaced mine all they have is 2nd or 3rd gen cables now. Had to drill the holes out a little. Hope I don't start having problems, but they are still new.
