which 727's had 4 gear planetarys #1467700
07/14/13 02:01 PM
07/14/13 02:01 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
want to build a trans for my drag car and want to find one to start with the best parts and go from there..any idea's?
Re: which 727's had 4 gear planetarys [Re: Plymouth340] #1467701
07/14/13 02:13 PM
07/14/13 02:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How big an engine and how heavy is your car ? 4 pinion planets may not be necessary. .
Re: which 727's had 4 gear planetarys [Re: JohnRR] #1467702
07/14/13 02:41 PM
07/14/13 02:41 PM
CEDAR RAPIDS
CEDAR RAPIDS
675 hp small block @ 2830 lbs..got a 1972 small block case to start with.
Re: which 727's had 4 gear planetarys [Re: Plymouth340] #1467703
07/14/13 04:53 PM
07/14/13 04:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The archives have some info on the planetaries.
http://www.moparts.org/Tech/Archive/auto/36.html
It should be noted that, after 40+ years, you never know what you'll find inside a 727...parts get swapped. Also worth noting is that 4-pinion planetaries aren't really any stronger than their 3-pinion cousins, the weak point is the splines in the aluminum front planet carrier. If you want reliability go with a steel front planetary.
