SB crank trigger picture? #1467287
07/13/13 03:00 PM
07/13/13 03:00 PM
AndyF Online content OP
AndyF  Online Content OP
Anyone have a good picture of a crank trigger mounted on a SB Mopar? I looked on the MSD website and they don't show anything mounted on an engine. Just trying to figure out where the bracket kit mounts on a SB.
Re: SB crank trigger picture? [Re: AndyF] #1467288
07/13/13 05:48 PM
07/13/13 05:48 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am not sure if this is a "good" shot or not. It will go on either side and I'll end up running it on the passenger side when I am done.
Bill
Re: SB crank trigger picture? [Re: 340Cuda] #1467289
07/13/13 06:43 PM
07/13/13 06:43 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
This is a poor picture. I mounted mine behind my motor plate.Maybe you can see the spacers I use.
Re: SB crank trigger picture? [Re: DavidDean] #1467290
07/14/13 02:18 AM
07/14/13 02:18 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think I got one......sort of.
BBC trigger kit with pick up bracket mounted to motor plate
Re: SB crank trigger picture? [Re: tubtar] #1467291
07/14/13 09:23 AM
07/14/13 09:23 AM
408Dust Offline
408Dust  Offline
Re: SB crank trigger picture? [Re: AndyF] #1467292
07/14/13 09:23 AM
07/14/13 09:23 AM
MD
ADakotaRTGuy Offline
MD
Magnum timing cover, but should not make a difference.
Re: SB crank trigger picture? [Re: ADakotaRTGuy] #1467293
07/14/13 01:24 PM
07/14/13 01:24 PM
Out West
408strokerdart Offline
Out West
MSD's bracket is designed to work on either side. It has an extra hole to accommodate this.
Re: SB crank trigger picture? [Re: 408strokerdart] #1467294
07/14/13 02:48 PM
07/14/13 02:48 PM
I see that now, especially in the last picture. The picture on the MSD site doesn't show the extra hole. They must have used a generic picture in the illustration that I looked at.
Re: SB crank trigger picture? [Re: AndyF] #1467295
07/15/13 01:15 AM
07/15/13 01:15 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Here's mine, I modified it for the belt drive adjuster and the notch on the out side is for clearance on my vacuum pump
Re: SB crank trigger picture? [Re: SB412DUSTER] #1467296
07/15/13 01:34 PM
07/15/13 01:34 PM
Looks like a nice clean install. Is that a Weber belt drive?
Re: SB crank trigger picture? [Re: AndyF] #1467297
07/16/13 02:46 AM
07/16/13 02:46 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Yes a short deck version
Re: SB crank trigger picture? [Re: AndyF] #1467298
08/07/13 10:27 AM
08/07/13 10:27 AM
I picked up a MSD crank trigger kit. Seems to fit okay after some minor modifications. Not a big fan of some of the parts in the kit but nothing that I can't fix.
Re: SB crank trigger picture? [Re: AndyF] #1467299
08/07/13 05:34 PM
08/07/13 05:34 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Nice looking front cover.
Re: SB crank trigger picture? [Re: TrWaters] #1467300
08/07/13 07:03 PM
08/07/13 07:03 PM
1 of 1!
Re: SB crank trigger picture? [Re: SB412DUSTER] #1467301
08/07/13 07:28 PM
08/07/13 07:28 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
This is the proto type that Direct Connection developed for their small block crank trigger. Dave Koffel gavce it to me.
home of the
Sox and Martin Hemi Duster
Re: SB crank trigger picture? [Re: HEMIFRED] #1467302
08/07/13 07:28 PM
08/07/13 07:28 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the wheel
home of the
Re: SB crank trigger picture? [Re: AndyF] #1467303
08/07/13 11:29 PM
08/07/13 11:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
1 of 1!
Are you planning to go to production with them?
Looks nice, like the O rings a lot.
Bill
Re: SB crank trigger picture? [Re: 340Cuda] #1467304
08/08/13 12:38 AM
08/08/13 12:38 AM
Should be available within a few weeks. Hughes Engines will have them.
Re: SB crank trigger picture? [Re: AndyF] #1467305
08/08/13 02:35 AM
08/08/13 02:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....got you thinking huh?
Re: SB crank trigger picture? [Re: SB412DUSTER] #1467306
08/08/13 10:48 AM
08/08/13 10:48 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Probably a dumb question but how do you set up the timing to switch it to the passenger side? The only way I can time mine with the crank trigger on the drivers side and see the timing marks is pull the radiator because of my procharger.
