Whats involved to convert a Magnum to a carburator? #1467122
07/13/13 12:34 AM
07/13/13 12:34 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Im having some issues with my 92 Dakota. 5.2 Auto, MPFI
It keeps throwing code 11, and will just shut off ignition power at random. Sometimes multiple timea a day, sometimes no issues for a week.
Its getting to the point I am not confident in driving it 140 miles each day.
I have changed the CPS about 4 months ago when the new trans went in, and all was fine until about 2 months ago when this started. (it happended to start the day after a waterpump change)
I originally thought maybe a wire got pinched, or insulation cracked during the swap, but there are no signs of this after several close inspections.
I am going to have a timing chain replaced, it has 140K on the clock. And just for poops, and giggles, may even stick a new CPS on it.
IF this doesnt solve the issue, I want to remove the injection, and go to a carb.
What do i need other than the following:
Carb style manifold
Carb
Distributor (most likely going to go Pertronix) Looking at the flamethrower III dizzy for an LA motor, is this the one I want to lose the computer control?
Ignition (see distributor)
Fuel pressure regulator with return line.
Now I'm not sure what to do about the 518 OD trans. I think the 92 is still a hydraulic lockup, so I only need to control the OD shift.
Can I retain the computer for this, or will I need to go with a system like the PATC vacuum switch, and pressure switch like would be used on a standard 727 to 518 swap?
Anything else I may be forgetting, or should change?
Re: Whats involved to convert a Magnum to a carburator? [Re: hp383] #1467123
07/13/13 12:57 AM
07/13/13 12:57 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Don't do it. A lot of hassle and expense for no gain. Your year of wiring would be OBD1 and it's super simple. If the crankshaft sensor has crapped out again, that will kill your fuel pump. Otherwise it may be your computer.
Re: Whats involved to convert a Magnum to a carburator? [Re: DaytonaTurbo] #1467124
07/13/13 01:38 AM
07/13/13 01:38 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I have tried swapping in a new MP performance computer.
It makes the issue even worse.
I need to have this truck be reliable, I'm disabled, and cant be getting stranded on the side of the road at the trucks whim.
I will sacrifice a few mileage points to gain reliability.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Whats involved to convert a Magnum to a carburator? [Re: hp383] #1467125
07/13/13 03:00 AM
07/13/13 03:00 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
It wouldn't be hard at all & you'll gain power & MPG most likely.
PATC kit Ignition isn't hard to wire at all
use a return style regulator
RPM Air Gap required & you have to make the Eddy work even though it's supposed to be the best one for the job To keep the A/C you have to make a hole & tap it for the heater hose nipple. They put it directly under the A/C compressor & none of their could be cast in bosses were in the right place
my 5.9 in my CrewCab got a solid 19 MPG hwy with OD & 4.11's w/33's @ 70 MPH
I'll take some pics tomorrow & show what it takes to make all the accessories work
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467126
07/13/13 12:43 PM
07/13/13 12:43 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Have you checked the main harness near the battery? There's a splice in there that is notorious for failing at the worst moment. Very common on those trucks. Sorry I can't be more specific but if you search the threads using the google feature, you should be able to find something.
Other things to check:
1. How old is the battery?
2. TPS and IAS (?) sensors
3. Fuel pump
I totally sympathize. I have a 93 5.2l that plays games too. One time it did it at a stoplight just after I bought a truckload of parts from John_RR as I was getting on the Mass Pike! Boy, was the guy behind me pissed! Did all of the above and just did a water pump. I still don't trust it, but I love my '93. Someday hope to a total restoration because I am sick of doing cars!
Common sense is a flower that does not grow in everybody's garden
Re: Whats involved to convert a Magnum to a carburator? [Re: Ron_M] #1467127
07/13/13 01:15 PM
07/13/13 01:15 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
3. Fuel pump
Checked spice in harness under the washer bottle area. Clean and happy there.
Battery is 4 months old
TPS and IAS less than 2 months old
Fuel pump, and filter, less than 4 months old
When this happens the ASD relay is being triggered,(which shuts down power to the coil, and fuel pump) so it pretty much has to be down to the timing chain is loose enough it is letting the timing wander too far out, or the CPS is just faulty.
I even stuck a new pickup coil in it and that didn't help..
Re: Whats involved to convert a Magnum to a carburator? [Re: hp383] #1467128
07/14/13 08:50 AM
07/14/13 08:50 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Coil failure is REAL common on the magnum engines, we use to see it all the time at the dealer, cheap to try too.
Re: Whats involved to convert a Magnum to a carburator? [Re: gdonovan] #1467129
07/14/13 01:10 PM
07/14/13 01:10 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Is there a more reliable aftermarket unit a person can put on? Pertronix, MSD, etc?
Or is there some other issue bringing on the coil failure.
Re: Whats involved to convert a Magnum to a carburator? [Re: hp383] #1467130
07/14/13 10:12 PM
07/14/13 10:12 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I'd like to know too!
Does the Magnum coil test the same at the older cylinder ones?
What was the symptom(s) of a coil failure?
It was 90 here today, my truck died twice, only to restart a short time later. I believe the coil is the original and has 158K on it.
Sorry to hp383 for hijacking your post
Re: Whats involved to convert a Magnum to a carburator? [Re: Ron_M] #1467131
07/18/13 12:16 AM
07/18/13 12:16 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's that pic Jamie!
The heater hose is designed to come up under the A/C
Where I moved mine to there was a blank boss for a 1/8" npt fitting
I'll measure the spacers needed to attach all the brackets & make them as functional as they can be using grade 8 bolts
Edelbrock was only partially thinking when they designed this intake
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467132
07/18/13 03:01 AM
07/18/13 03:01 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's the spacers & bolts
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467133
07/18/13 03:04 AM
07/18/13 03:04 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Another pic
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467134
07/18/13 03:08 AM
07/18/13 03:08 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's a pic of the gaps
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467135
07/18/13 03:14 PM
07/18/13 03:14 PM
P
Paul_Fancsali Offline
P
Change the coil they will often cause this type of issue Also check rest of wiring as you have done but carefully go over all the computer wires for cracks
Re: Whats involved to convert a Magnum to a carburator? [Re: Paul_Fancsali] #1467136
07/26/13 11:08 PM
07/26/13 11:08 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
So here's the next issue. How do I route thet throttle cable to work on a carb?
Do I need to replace it with something from an alternate year?
The MPI loops over to the passenger side. It looks like it will be much to long to work.
Re: Whats involved to convert a Magnum to a carburator? [Re: hp383] #1467137
07/27/13 01:27 AM
07/27/13 01:27 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
91 down cable
Re: Whats involved to convert a Magnum to a carburator? [Re: BulletBob] #1467138
07/27/13 11:58 AM
07/27/13 11:58 AM
Dirty South, MS
mopowered Offline
mopowered  Offline
Dirty South, MS
Agree that its a ton of work for little gain. When you changed the CPS -did you use an aftermarket / non-Mopar / cheaper part? I've run into this several times where using a Mopar CPS was the solution. Don't ask me why but it works.
Re: Whats involved to convert a Magnum to a carburator? [Re: mopowered] #1467139
07/27/13 03:44 PM
07/27/13 03:44 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I used a non-mopar part, but it wasnt the cheaper. I had my choice of the $45 one or the $100ish one. I went with the higher price as it was from supposedly the better product line.
I had the Dodge service tech tell me that the non-Mopar items I had were causing the issue, yet when THEY changed the coil, they uses a MasterCraft coil from O'Reilly, and didn't touch the CPS...
I will see about getting a Mopar CPS to have in my tool box on hand. But it seems funny that a dealer part would work better than the top line aftermarket.
Re: Whats involved to convert a Magnum to a carburator? [Re: mopowered] #1467140
07/27/13 03:55 PM
07/27/13 03:55 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
As far as a lot of work for the little bit of gain, I am not doing this to gain any performance, or power. In fact I fully expect to lose some of each, and maybe even a point or two in MPG.
But IF the thing acts up on me again, and keeps crapping out CPS units, I have to do something to make it a reliable driver.
I have spent to much to just toss it aside, or sell it down the road.
It has new slotted and drilled rotors, new calipers, new pads, new drums, new rear shoes, new wheel cylinders, new brake lines, new fuel pump, new wheels, new tires, new shocks on all corners, new transmission, new higher stall converter, new rack and pinion steering, new tie-rods, a fresh alignment, not to mention the lower intake gasket fixed, new injector seals, the typical tune up items, plugs, wires, cap rotor and a few others I'm sure I forgot.
So losing the computer controlled ignition would be a better option financially than trying to sell a 92 Dakota with a new driveline, and upgraded/replaced mechanical items that will die on you unexpectedly, and starting over.
Basically I'm in to deep to toss it away now. My hope was after the upgrades to have a decent little driver that would last me 50-70K without any major issues.
