power steering issues...I need some help #1466716
07/12/13 01:51 AM
07/12/13 01:51 AM
scarface06 Offline OP
Was changing out the transmission on my '68 440 Satellite and decided to change out the power steering gear box cause the seals were a little leaky. The old box worked just fine. Got the new Cardone box in and transfered the high pressure fitting on top and the return valve body. Put it in and got it running, and it took two hands to turn it. Very hard. Figured it was just a crappy cheap box so I put the old one back it that worked just fine. Put the fitting and return body back on and it doing the same thing.
The steering linkage is not binding up, its like there is no belt on the pump. I seem to be getting good flow coming out of pump and what appears to be good return coming out of gear box.
Before I did all this I could steer it with one finger. Now its impossible to drive. I've put it back the way it was. Not sure if maybe the pump just happen to go out at the same time I changed the gear box.
I'm really scratching my head on this one.
Re: power steering issues...I need some help [Re: scarface06] #1466717
07/12/13 08:12 AM
07/12/13 08:12 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
air in the lines? did you bleed it?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: power steering issues...I need some help [Re: amxautox] #1466718
07/12/13 09:41 AM
07/12/13 09:41 AM
I did bleed it. I probably have an hour of run time on it at this point, turning the wheel lock to lock.
Re: power steering issues...I need some help [Re: scarface06] #1466719
07/12/13 09:45 AM
07/12/13 09:45 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Sounds like you've got a bad box. I'm sure someone will chime in and tell you what the issue is.
I would just change the seals on the old box (<$10) and put it back in. I changed the input shaft seal in ~10 minutes, which solved my leak I had a few months ago.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: power steering issues...I need some help [Re: Uhcoog1] #1466720
07/12/13 01:58 PM
07/12/13 01:58 PM
I've put the old box back in. It's giving me the same issues.
Re: power steering issues...I need some help [Re: scarface06] #1466721
07/12/13 04:01 PM
07/12/13 04:01 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Did you cycle the wheel back and forth with the front jacked up and the engine off?
Mopar to the bone!!!
Re: power steering issues...I need some help [Re: 72Swinger] #1466722
07/12/13 05:04 PM
07/12/13 05:04 PM
Okay, got it fixed. The pressure spring/piston set up inside the pump was stuck. Pulled the hose at the pump off, pulled the fitting out of the pump. The spring and piston should have came almost all the way out on it's own. Worked it with a screw driver in and out till the spring pushed the piston out. Cleaned it, put it back, works great.
Only took me a weeks worth of work to figure out it was a 3 minute fix. The guys as Steer & Gear directed my where to make the fix.
