Page 1 of 3 1 2 3
Aluminum Driveshaft? #1466280
07/10/13 11:29 PM
07/10/13 11:29 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Any of you guys that road race use an aluminum driveshaft? I am getting a new steel one made and it's only $100 more for aluminum one. Wondering if it was worth it for the weight savings? Any opinions, pros and cons of steel vs. aluminum?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Aluminum Driveshaft? [Re: RylisPro] #1466281
07/11/13 12:23 AM
07/11/13 12:23 AM
IN
ahy Offline
ahy  Offline
IN
Opinion... I thing the biggest benefit of aluminum is to protect a fragile rear with drag starts. Not a factor with RR. Unless there is a major weight savings I'd go steel for strength and fatigue resistance.
Re: Aluminum Driveshaft? [Re: ahy] #1466282
07/11/13 01:06 AM
07/11/13 01:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I run a 3.5" AL shaft. My thinking was stability at high shaft speed. The jury is still out on that. The OEM's are using them behind Diesel engines and everything else too.
Mopar to the bone!!!
Re: Aluminum Driveshaft? [Re: RylisPro] #1466283
07/11/13 01:12 AM
07/11/13 01:12 AM
AndyF Offline
AndyF  Offline
We put an aluminum driveshaft in Tim's Valiant last time it was upgraded. Pretty much needed the aluminum in order to keep the weight reasonable. At 160 mph the driveshaft speed is starting to get high enough that we needed the larger shaft diameter. A large diameter shaft gets heavy if it is steel.
Re: Aluminum Driveshaft? [Re: AndyF] #1466284
07/11/13 02:10 AM
07/11/13 02:10 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Bonneville car?
Re: Aluminum Driveshaft? [Re: AndyF] #1466285
07/11/13 02:29 AM
07/11/13 02:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What was the diameter and wall thickness? What U-joints did you use?
Re: Aluminum Driveshaft? [Re: ahy] #1466286
07/11/13 04:17 AM
07/11/13 04:17 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I beg to differ on the first part. It simply takes less power to rotate a lighter weight part than a heavyweight part.
Since a dragrace is one long acceleration and increase in RPM of the driveshaft, there are benefits.
I also think it would benefit a roadracer since car and driveshaft speeds are constantly changing during the race.
Re: Aluminum Driveshaft? [Re: BigBlockMopar] #1466287
07/11/13 11:46 AM
07/11/13 11:46 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Lighter weight = faster acceleration, quicker deceleration, even overall better g-force in the corners... simply, physics (less weight is always better, as long as the strength for critical components is not sacrificed (i.e safety).
Re: Aluminum Driveshaft? [Re: Mopar Mitch] #1466288
07/11/13 12:03 PM
07/11/13 12:03 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I think one of the most important things is who's making it. I've seen runout on too many custom driveshafts. I run and sell Dynotech shafts. Mine is 3.5 Alum with 1350 joints. Runout under .010. Very smooth at speeds up 130 so far.
Re: Aluminum Driveshaft? [Re: BigBlockMopar] #1466289
07/11/13 12:59 PM
07/11/13 12:59 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
It's all rotating mass and moments of inertia. The larger MOI you have, the more the shaft is going to want to resist rotating. The lighter mass and the closer it is to the center of rotation, the better.
Re: Aluminum Driveshaft? [Re: dart4forte] #1466290
07/11/13 02:06 PM
07/11/13 02:06 PM
AndyF Offline
AndyF  Offline
Bonneville car?
Road race car. 1968 Valiant. Couple of articles in Mopar Muscle show the build.
Re: Aluminum Driveshaft? [Re: RylisPro] #1466291
07/11/13 02:43 PM
07/11/13 02:43 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Thanks for all the advice, I think I will go aluminum
My biggest concern would be denting the aluminum driveshaft if and when I go off track, hopefully my exhaust system will help shield it from any damage.
Which aluminum driveshaft vendor did you guys buy from or recommend?
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Aluminum Driveshaft? [Re: RylisPro] #1466292
07/11/13 04:48 PM
07/11/13 04:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mine is made from 3.5" OD x .125 DOM FYI. http://www.actionmachineinc.com/aluminumdriveshaft.aspx
Re: Aluminum Driveshaft? [Re: RylisPro] #1466293
07/11/13 05:29 PM
07/11/13 05:29 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Steel ones dent too. I wouldn't worry about it.
thanks
They are not brain surgery. Most stock cars have them now. Just find a local driveshaft shop that the local hot rods and racer guys all go to a respect.
Re: Aluminum Driveshaft? [Re: RylisPro] #1466294
07/11/13 08:09 PM
07/11/13 08:09 PM
Cincinnati, Ohio
Challenger 1 Online tonguue
Challenger 1  Online Tonguue
Cincinnati, Ohio
I had this one made here in town at the local "driveline" shop.
I remember it was not much more $$ than steel so I said WTF make it out of aluminum last time I needed a drive shaft.
The only thing I wanted to point in my case the diameter is bigger than my stock steel shaft. It fit but is real close to my mufflers but does not hit them.
It has held up in my 500hp car.
I weighed it, it was much lighter, don't remember the numbers.
Re: Aluminum Driveshaft? [Re: Challenger 1] #1466295
07/12/13 12:34 AM
07/12/13 12:34 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I picked up a brand new aluminum drive shaft with new 1350 u joints that was out of a ford van, found it on Craigslist for 50 bucks.
Re: Aluminum Driveshaft? [Re: Darryls-Demon] #1466296
07/12/13 12:27 PM
07/12/13 12:27 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
I pulled mine out of an old crown vic cop car, also 1350 joints.
thanks
Aluminum has a memory, if you bend it a little, it will go back on its own. It may be softer than steel, but will less likely dent as easily.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Aluminum Driveshaft? [Re: jrlegacy23] #1466297
07/12/13 05:24 PM
07/12/13 05:24 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
How long are the typical ford crown vic and van driveshafts?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Aluminum Driveshaft? [Re: AlexP] #1466298
07/12/13 08:53 PM
07/12/13 08:53 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
I don't remember the overall length, but I moved my rear end back 1.25" and still had to cut around 1 5/8" out of the shaft.
Re: Aluminum Driveshaft? [Re: RylisPro] #1466299
07/12/13 11:25 PM
07/12/13 11:25 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
I guess I'm a little late to the party. I have a 71 Challenger small block and when it came time for a drive-shaft I opted for aluminum. Had mine built by Denny's Drive shaft they were running a special and the aluminum was not much more than steel. I autocrossed the car for years, and have done a reasonable amount of road racing. Took the car off track in the dirt at Willow Springs, no damage to the drive shaft. You can probably have one built locally and save the shipping.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Page 1 of 3 1 2 3
