Re: Aluminum Driveshaft?
[Re: ahy]
#1466282
07/11/13 01:06 AM
07/11/13 01:06 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I run a 3.5" AL shaft. My thinking was stability at high shaft speed. The jury is still out on that. The OEM's are using them behind Diesel engines and everything else too.
Mopar to the bone!!!
[Re: AndyF]
#1466284
07/11/13 02:10 AM
07/11/13 02:10 AM
Posts: 16,160 Mesa, Arizona
dart4forte
Mesa, Arizona
We put an aluminum driveshaft in Tim's Valiant last time it was upgraded. Pretty much needed the aluminum in order to keep the weight reasonable. At 160 mph the driveshaft speed is starting to get high enough that we needed the larger shaft diameter. A large diameter shaft gets heavy if it is steel.
Bonneville car?
[Re: AndyF]
#1466285
07/11/13 02:29 AM
07/11/13 02:29 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
What was the diameter and wall thickness? What U-joints did you use?
[Re: ahy]
#1466286
07/11/13 04:17 AM
07/11/13 04:17 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Opinion... I thing the biggest benefit of aluminum is to protect a fragile rear with drag starts. Not a factor with RR. Unless there is a major weight savings I'd go steel for strength and fatigue resistance.
I beg to differ on the first part. It simply takes less power to rotate a lighter weight part than a heavyweight part. Since a dragrace is one long acceleration and increase in RPM of the driveshaft, there are benefits.
I also think it would benefit a roadracer since car and driveshaft speeds are constantly changing during the race.
[Re: BigBlockMopar]
#1466287
07/11/13 11:46 AM
07/11/13 11:46 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Lighter weight = faster acceleration, quicker deceleration, even overall better g-force in the corners... simply, physics (less weight is always better, as long as the strength for critical components is not sacrificed (i.e safety).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: BigBlockMopar]
#1466289
07/11/13 12:59 PM
07/11/13 12:59 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
It's all rotating mass and moments of inertia. The larger MOI you have, the more the shaft is going to want to resist rotating. The lighter mass and the closer it is to the center of rotation, the better.
[Re: dart4forte]
#1466290
07/11/13 02:06 PM
07/11/13 02:06 PM
Posts: 31,060 Oregon
AndyF
Bonneville car?
Road race car. 1968 Valiant. Couple of articles in Mopar Muscle show the build.
[Re: RylisPro]
#1466291
07/11/13 02:43 PM
07/11/13 02:43 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Thanks for all the advice, I think I will go aluminum My biggest concern would be denting the aluminum driveshaft if and when I go off track, hopefully my exhaust system will help shield it from any damage. Which aluminum driveshaft vendor did you guys buy from or recommend? thanks
[Re: RylisPro]
#1466292
07/11/13 04:48 PM
07/11/13 04:48 PM
72Swinger
Nebraska
[Re: RylisPro]
#1466293
07/11/13 05:29 PM
07/11/13 05:29 PM
autoxcuda
So Cal
Steel ones dent too. I wouldn't worry about it.
thanks ..
They are not brain surgery. Most stock cars have them now. Just find a local driveshaft shop that the local hot rods and racer guys all go to a respect.
[Re: RylisPro]
#1466294
07/11/13 08:09 PM
07/11/13 08:09 PM
Challenger 1
Cincinnati, Ohio
I had this one made here in town at the local "driveline" shop. I remember it was not much more $$ than steel so I said WTF make it out of aluminum last time I needed a drive shaft. The only thing I wanted to point in my case the diameter is bigger than my stock steel shaft. It fit but is real close to my mufflers but does not hit them. It has held up in my 500hp car. I weighed it, it was much lighter, don't remember the numbers.
[Re: RylisPro]
#1466299
07/12/13 11:25 PM
07/12/13 11:25 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
I guess I'm a little late to the party. I have a 71 Challenger small block and when it came time for a drive-shaft I opted for aluminum. Had mine built by Denny's Drive shaft they were running a special and the aluminum was not much more than steel. I autocrossed the car for years, and have done a reasonable amount of road racing. Took the car off track in the dirt at Willow Springs, no damage to the drive shaft. You can probably have one built locally and save the shipping.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
