The Firecore billet distributor will clear that air grabber assembly and is a much better distibutor than the MP unit and more compact than the MSD pro-billet. Also much more economical than the MSD....about $100 cheaper. Much easier to tune for mechanical advance and way more adjustable.
Available in several models ;
(1) Ready to Run billet with built-in ECU so there's no ballist resistor or external box....really cleans up the engine bay.
(2) Plug & Play billet that uses an external box....snaps right into the MP wiring harness and works with orange/chrome boxes, revinator or msd/crane/mallory multiple discharege boxes.
(3) Billet mechanical that has no vacuum advance and requires an external box ; MSD/Crane/Mallory etc...
* all Firecore distributors work with a factory tan cap or you can opt for a male terminal HEI cap.
Ron
Here is a pic of the Ready to Run distributor with matching coil with HEI terminal cap
