'68 Dart w/'66 225, oil pan/center link interference #1466171
07/10/13 10:27 PM
07/10/13 10:27 PM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
In my '68 Dart I recently installed a good running '66 225/904 that came out of a '66 Valiant. My Dart is an original 225 car. The center link is only about 1/8" from the oil pan directly in line with the oil drain plug.
Does anybody know if an A-body V8 center link would add some clearance? I wouldn't mind hammering on the pan a bit, but I'm evaluating my options at this point. I don't want to pull the engine or the pan if I don't have to.
Thanks!
Re: '68 Dart w/'66 225, oil pan/center link interference [Re: 68red440] #1466172
07/10/13 10:42 PM
07/10/13 10:42 PM
I think the 66 pan is slightly different than the 68 pan. The 64-66 V8 centerlink does have a lower drop. If nobody knows go here www.slantsix.org they'd know in a heartbeat
Re: '68 Dart w/'66 225, oil pan/center link interference [Re: RapidRobert] #1466173
07/10/13 11:19 PM
07/10/13 11:19 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is no "V-8" link for the '68-72 A bodies, they used the same one for 6 & 8 cyl.
The 63-66 link is different and will not work.
You need the correct pan and pickup.
Re: '68 Dart w/'66 225, oil pan/center link interference [Re: slantzilla] #1466174
07/11/13 07:41 AM
07/11/13 07:41 AM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
Thanks for the info. It may not be the answer I was hoping for, but now I know how to proceed.
Re: '68 Dart w/'66 225, oil pan/center link interference [Re: 68red440] #1466175
07/11/13 08:25 AM
07/11/13 08:25 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Used to go through the same thing with my '66. The later pan came oh-so-close to working, but was not close enough.
Re: '68 Dart w/'66 225, oil pan/center link interference [Re: slantzilla] #1466176
07/11/13 10:29 AM
07/11/13 10:29 AM
The 63-66 link is different and will not work. You need the correct pan and pickup.
Oh that's right, I missed that it was a 68 vehicle. correct pan/pickup
