Rocky Update from Daurity's shop!
#1465954
07/10/13 03:35 PM
07/10/13 03:35 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Stephen just texted me and said he can get the 1 7/8" TTI B/E body headers to fit in the Rocky, just have to reroute one #7 tube on the driver's side and "massage" a tube (probably #8) on the Pass side. Psyched about getting a proper sized system on the 414 finally and getting rid of the 1 5/8" 'pipe-cleaners' that were on there. Really can't say enough great things about Stephen and Mike Daurity, awesome people with awesome skillz...plus always a heapin' helping of that NC hospitality Hoping Stephen will post up some pics if he's up to it
Re: Rocky Update from Daurity's shop!
[Re: Streetwize]
#1465957
07/11/13 09:44 AM
07/11/13 09:44 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Let me know when you're heading to the track.
[Re: Streetwize]
#1465960
07/11/13 11:17 AM
07/11/13 11:17 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
What is the WB on the Rocky?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1465961
07/11/13 11:25 AM
07/11/13 11:25 AM
Streetwize
Weddington, N.C.
85.5" But once it's off the line it goes straighter than ANYTHING I've ever driven in 32 yrs, Chip can tell you (since he stood behind it at the line) it tracks like it was on rails. What I think helps it is the steering box is a very slow ratio and the weight distribution is uncannily well balanced, the CG is directly under my butt! (see the sketch I did a couple yrs back)
[Re: Kindafast]
#1465963
07/11/13 05:51 PM
07/11/13 05:51 PM
Streetwize
Weddington, N.C.
Just about ready for ya, Joe Been looking forward to that for way too long a time, my friend!!
[Re: Streetwize]
#1465964
07/11/13 06:08 PM
07/11/13 06:08 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Let me know ,I can meet up somewhere with you and finally get to see the Rocky run. Then talk talk and repeat..
6.50 @105.26
[Re: Streetwize]
#1465966
07/11/13 08:19 PM
07/11/13 08:19 PM
Posts: 3,695 nc
emarine01
nc
I'm expecting the bigger tubes to kill just a little bit of the bottom end and maybe soften the converter hit .... Na the 1 5/8 jake brake headers snuffed that too, The 1 7/8 tubes will cut that small block loose from the hit to max turns
[Re: Streetwize]
#1465972
07/23/13 02:55 PM
07/23/13 02:55 PM
an8sec70cuda
Hurry up and get it done. Street car shootout Friday night at Darlington!
[Re: an8sec70cuda]
#1465973
07/23/13 03:08 PM
07/23/13 03:08 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Does Rocky have a roll bar/cage in it?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
