Re: stroker crankshaft brand
[Re: JohnRR]
#1465656
07/10/13 01:10 PM
07/10/13 01:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Actually John, there IS a brand called Precision Engine....not sure if thats what they are using, but its an old company that used to be involved with the same people as RPM International, or some derivitive of etc. Its an offshore forged piece if its what I am thinking. Usually a low price point with a very limited selection of sizes.
RIP Monte Smith
[Re: JohnRR]
#1465658
07/10/13 02:01 PM
07/10/13 02:01 PM
That is not a BRAND, it is a DESCRIPTION ...
http://www.precisionengineparts.com
How many times can one person be wrong before they quit trying to pretend they know everything....
[Re: CompWedgeEngines]
#1465659
07/10/13 03:21 PM
07/10/13 03:21 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for that correction ... looks like a description the way it's phrased above by the OP ...
If this is the case then I'm curious as to what terms the OP used to search out this supplier and came up empty ... not that it matters , to me anyway ...
[Re: ]
#1465660
07/10/13 04:28 PM
07/10/13 04:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
You might want to go to the judges , but I am pretty sure it is 8. And this is for a calender year , not 12 month aggregate. Or is it fiscal year ? Oh , crap...........there goes another. Now I'm down to three and I've still got nearly five months to go.
[Re: J_BODY]
#1465663
07/11/13 01:53 AM
07/11/13 01:53 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I have several of them and they are nice for the $$$. For my engines we sent out standard mopar journal 4.150" stroke cranks and had them offset ground to 4.250 with a 2.200" rod journal. I also had them turn down the counter weights while it was at the grinder. I also am using h beam RPM International rods with ARP 2000 bolts fwiw. I think Cab may have a PEP crank in one of his motors as well. My PEP stuff was incredibly reasonable in price because I bought a pile of cranks all at once. I was also able to save on freight by having the rep for the crank grinder pick them up and drop them off at the local machine shop. PS I have a NIB big main 4.150 stroke crank if anybody needs one.
[Re: Jeremiah]
#1465664
07/11/13 03:02 AM
07/11/13 03:02 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
Jeremiah, I haven't used any if the ones I bought yet, maybe soon the crank in my Duster was a SCAT, I think It is a 6 bolt 4.150 BB crank cut down to B motor mains and counter balances, offset ground form 4.150 Mopar rod size to BB 2.200 with a 4.300 stroke, 6.800 long CAT brand H beam steel rods
[Re: Cab_Burge]
#1465665
07/11/13 05:06 AM
07/11/13 05:06 AM
Jeremiah
Rogue River, OR
Thank you for the correction. I have a hard time keeping up these days!
