what to do with 69 dart gts #1465186
07/09/13 10:45 AM
07/09/13 10:45 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
my 69 GTS is getting paint. Its registered on the GTS registry. I do not have the original 340 and 727. I am trying to decide what engine/transmission combo to go with.
I have
a 400 and a 440 crank turned down to 400 mains
a complete cast crank 440
a LA style 360 with mag heads that are pocket ported
a big and small block 727 and a 4 speed.
The original plan was the 360. Its 30 over and decked ready to go together... I love my 74 Scamp 440... what's your thoughts?
I want a hot street car. It may never see the track.
Re: what to do with 69 dart gts [Re: mopfried] #1465187
07/09/13 10:53 AM
07/09/13 10:53 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
With any semblance of traction 440 A bodies just straight out haul! Its kind of a pain because fenderwell headers hinder your steering ability/tire selection, and underchassis are tight in those cars, but a typical 509 cam iron head 440 with a single plane intake and 4.10s is pretty streetable and really romps in an A body. So I vote 440 or 451
The low deck will fit nicer/easier, so you've got the ability to have the best of both worlds with the 451, so I say do that from the perspective of ignoring cost/what you already have in the 360. I prefer 4 speed cars 100 %, but as stated above 440 A bodies are lethal, and particularly impressive when you have a 727 to just pour it on. Id say that has to be your preference.
Re: what to do with 69 dart gts [Re: GTX MATT] #1465188
07/09/13 12:28 PM
07/09/13 12:28 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I also have a 69 GTS 340, now 440 but if i was to do it again in a street car, i would keep the small block. The 440 is very torquey but for the street the sb will run rings around the big motor handling wise, also easier to work on. TTI's fit and are underchassis.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what to do with 69 dart gts [Re: mopfried] #1465189
07/09/13 01:41 PM
07/09/13 01:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Put a 4" crank in your 360 and have the power of a 440 in a small package, plus it will handle a ton better. Not to mention it a much neater package.
Re: what to do with 69 dart gts [Re: justinp61] #1465190
07/09/13 01:52 PM
07/09/13 01:52 PM
NJ
rth Offline
rth  Offline
NJ
I vote for the 440,auto. Even if you use fenderwell headers it's still worth it.
Re: what to do with 69 dart gts [Re: mopfried] #1465191
07/09/13 02:02 PM
07/09/13 02:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I currently own a RR with a 451 stroker and 4 speed. It has more than enough torque that makes the car really fun to drive. I run the stock magnum manifolds with 2.5" exhaust through Flowmasters. Motor has more than enough HP and torque for the steet. I wouldn't let headers hold up your decision. If it's not going to see the track then I'd go with the stock magnum manifolds or maybe the Schumacker headers.
Of course you'll need to strengthen the chassis, frame connectors or torque boxes, beef up the front suspension with a bigger than stock sway bar etc.
If it's an original GTS my preferance would be to stay as close to stock as possible
Re: what to do with 69 dart gts [Re: justinp61] #1465192
07/09/13 02:09 PM
07/09/13 02:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Put a 4" crank in your 360 and have the headflow of a 360 in a larger package
Fixed it for ya
Re: what to do with 69 dart gts [Re: GTX MATT] #1465193
07/09/13 02:14 PM
07/09/13 02:14 PM
Alabama
BigMoneyLewis Offline
Alabama
My vote would be to find a correct dated 340 .
Greg
gregward@mchsi.com phone 256-852-0955
Re: what to do with 69 dart gts [Re: BigMoneyLewis] #1465194
07/09/13 03:23 PM
07/09/13 03:23 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Smallblock with a 4 inch crank. Especially since it's originally a 340 car.
The smallblock A-bodies were one of Mopar's best driving combos, why wreck it with another 100lbs of cast iron over the front tires? These days getting rid of the poor flowing Small block heads is super easy as well. I just don't see any reason to go big block unless you want to go faster than 10's.
Sheldon
Re: what to do with 69 dart gts [Re: BigMoneyLewis] #1465195
07/09/13 03:25 PM
07/09/13 03:25 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I have looked around for a correct dated 340, it was a late 68 build so it would have to be a 68 340. Not an easy find. It is an original GTS with a fender tag. I do have ITT 1-7/8 BB under chassis headers.
Re: what to do with 69 dart gts [Re: mopfried] #1465196
07/09/13 03:35 PM
07/09/13 03:35 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I've seen several 68 blocks here lately
Re: what to do with 69 dart gts [Re: dart4forte] #1465197
07/09/13 03:49 PM
07/09/13 03:49 PM
Wahoo Nebr
vette1986 Offline
vette1986  Offline
Wahoo Nebr
I vote for a 451 stroker put a set of aluminum 452 heads on it to lighten the load along with a set of headers and aluminum intake. Paint it all orange put a 383 pie tin on top and suprise a few people. I bet you would shave off 60-70 lbs and have a "close" to stock look. that is until you mash the pedal!!
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: what to do with 69 dart gts [Re: vette1986] #1465198
07/09/13 04:00 PM
07/09/13 04:00 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I have a 340 short block.. date coded 9-9-68, 9 B 274167, 2780930-340-7.
Stock bore, never rebuilt.. needs rebuilding as its sat indoors for many years but very dirty.
IF YOU'RE SERIOUSLY INTERESTED (maybe it belongs to your car?)... Contact me ASAP as I may be selling it very soon.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"
Re: what to do with 69 dart gts [Re: Mopar Mitch] #1465199
07/09/13 04:11 PM
07/09/13 04:11 PM
dogdays Offline
dogdays  Offline
Use a smallblock, 4" crank, your Mag =heads unless you can spring for Edelbrocks.
Check out the dyno sheets, a 400 inch smallblock that's well thought out will make 500 lb-ft of torque, be much easier to fit the headers to and will be more fun to drive. It's a pretty cool car, the GTS was more of a handling car so keep it that way. ESPECIALLY if you already have a bigblock A-body.
R.
Re: what to do with 69 dart gts [Re: RUNCHARGER] #1465200
07/09/13 11:10 PM
07/09/13 11:10 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Sheldon
What he said. A 416 small block with a mild hydraulic cam, WELL DONE J heads, LD340 intake (painted engine color), a fresh AVS from a 440, open OEM 340 air cleaner, 1 5/8 headers and a well executed exhaust. With a stock converter and 3.23's you'd have a sleeper 12 second Dart.
Re: what to do with 69 dart gts [Re: cudadoug] #1465201
07/10/13 12:16 AM
07/10/13 12:16 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I do have some 340 2.02 valve heads that have had some work done on them. They are open chamber and the 360 has been decked for the pistons I have to be about .005 in the hole. I have a comp 280 cam, several small block intakes and carbs. A new set of coated SB headers that are 1-5/8 I believe. I guess the best small block senario would be 4" crank and aluminum heads? Im a mopar nut.
So if I were to use the 360 as is, Speed pro flattops, stock stoke and mangnum ported heads, 280 cam, 1.6 roller rockers, stip dominator intake or M-1... how would that compair real world to a stroker with worked heads?
I have lots of options...
Re: what to do with 69 dart gts [Re: cudadoug] #1465202
07/10/13 12:16 AM
07/10/13 12:16 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Re: what to do with 69 dart gts [Re: cudadoug] #1465203
07/10/13 12:25 AM
07/10/13 12:25 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I vote stroker small block. My FAST legal 340/430 dynoed at 512 hp and 540 tq. It will spank a LOT of big blocks and it weighs a pile less.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: what to do with 69 dart gts [Re: mopfried] #1465204
07/10/13 02:26 AM
07/10/13 02:26 AM
cudadoug Offline
cudadoug  Offline
A well built yet streetable 3.58 stroke 360 will yield 450 HP and 450 ft.lbs. Same well built 4.00 stroke street friendly small block will produce 480-500 HP and at least 500 ft.lbs.
Having said that, depending on your budget (using what you already have) a street friendly 360 can still produce ets deep in the 12's in a "stock" chassis with a mild gear and the right converter/cam combo.
Re: what to do with 69 dart gts [Re: cudadoug] #1465205
07/10/13 09:11 AM
07/10/13 09:11 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
lot's of good info but those stroker builds can get costly
and complicated.
For all round stopping,handling and street performance a
warm 360 is about as good as it gets in an A body.
..very easy to 400 hp!
