Re: Upper control arm torque for adjustment bolts?
[Re: 5spdcuda]
#1465060
07/09/13 12:35 AM
07/09/13 12:35 AM
Posts: 9,312 SoCal
68HemiB
SoCal
Another vote for what he said.
Down to just a blue car now.
[Re: Pacnorthcuda]
#1465061
07/09/13 01:27 AM
07/09/13 01:27 AM
RapidRobert
You want em real tight but 145 ft lbs is a misprint. EDIT I'd suggest 85. I've heard reports 65 is too low (cam moved)
[Re: RapidRobert]
#1465062
07/09/13 01:33 AM
07/09/13 01:33 AM
Posts: 704 USA
rftroy
USA
The 145 ft-lb is for the lower control arm pivot nut.
The upper control arm torque is 65 ft-lb. Use a torque wrench.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1465063
07/09/13 09:07 AM
07/09/13 09:07 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I started doing alingments in the late 60s.Never torqued an upper arm.All you have to do is get them tight.Its almost like a torque setting for front wheel bearings.after you do a few you just get a feel for the setting.Most its hard enough to get a wrench on.Let alone in the rust belt where they dont want to turn.GMs we had a special SnapOn ratchet and sockets for the nuts.Rocky
Chrysler Firepower
