Upper control arm torque for adjustment bolts? #1465057
07/08/13 10:38 PM
07/08/13 10:38 PM
Kirkland, Washington
Pacnorthcuda Offline OP
E body, these are 1/2" (I think) fine thread. FSM says 145lbs----that strikes me as really high.
What say the experts?
Re: Upper control arm torque for adjustment bolts? [Re: Pacnorthcuda] #1465058
07/08/13 10:46 PM
07/08/13 10:46 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
It's hard enough to get a wrench on them when doing a front end alignment, much less a torque wrench. Just make sure they are good and tight. I would also use anti-sieze on the bolt shafts and the threads. Sure makes getting them back out again at a later date easier.
Re: Upper control arm torque for adjustment bolts? [Re: 5spdcuda] #1465059
07/08/13 11:29 PM
07/08/13 11:29 PM
Thanks Hugh....good n tight it is.
Re: Upper control arm torque for adjustment bolts? [Re: 5spdcuda] #1465060
07/09/13 12:35 AM
07/09/13 12:35 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Another vote for what he said.
Down to just a blue car now.
Re: Upper control arm torque for adjustment bolts? [Re: Pacnorthcuda] #1465061
07/09/13 01:27 AM
07/09/13 01:27 AM
You want em real tight but 145 ft lbs is a misprint. EDIT I'd suggest 85. I've heard reports 65 is too low (cam moved)
Re: Upper control arm torque for adjustment bolts? [Re: RapidRobert] #1465062
07/09/13 01:33 AM
07/09/13 01:33 AM
USA
rftroy Offline
rftroy  Offline
USA
The 145 ft-lb is for the lower control arm pivot nut.
The upper control arm torque is 65 ft-lb.
Use a torque wrench.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Upper control arm torque for adjustment bolts? [Re: rftroy] #1465063
07/09/13 09:07 AM
07/09/13 09:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I started doing alingments in the late 60s.Never torqued an upper arm.All you have to do is get them tight.Its almost like a torque setting for front wheel bearings.after you do a few you just get a feel for the setting.Most its hard enough to get a wrench on.Let alone in the rust belt where they dont want to turn.GMs we had a special SnapOn ratchet and sockets for the nuts.Rocky
Chrysler Firepower
