Re: half groove bearing or full groove
[Re: BeeSuper]
#1464798
07/08/13 03:06 PM
07/08/13 03:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just pulled my W-2 stroke apart the other day... it has full groove mains and those bearings(both mains and rods) looked like new.. I replaced them but could have put them right back in... that engine has been running 6 years in the race car... its going in the Rampage now.. I replaced the bearings with the same part number
[Re: MR_P_BODY]
#1464799
07/08/13 03:18 PM
07/08/13 03:18 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
What is actually the very best (for racing/hi-perf) is to use 3/4 grooved bearings... the top should be fully grooved; the bottom should be grooved at the outer edges ~25% per side so to allow the bottom to be solid. That design is proven to provide the bottom thrust face being solid to absorb the greatest amount of force. I think Federal-Mogul (via their "Speed Pro" line) sells 3/4 grooved bearings. ("Fully-grooved" is yester-year's technology.) You can call the Federal-Mogul Tech-Line and discuss this with them.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1464800
07/08/13 03:49 PM
07/08/13 03:49 PM
MR_P_BODY
Yes they are... a well know indy builder told me that the best is 5/8 of the diameter but we dont have that so the 3/4 would be next... and in cases they are hard to find for our stuff
[Re: 52savoy]
#1464806
07/08/13 07:36 PM
07/08/13 07:36 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
groovy.... but you and Cab are yester-year's technology
I didn't think I was old but must be. I use full grove mains also.
[Re: dusturbd340W5]
#1464810
07/08/13 09:41 PM
07/08/13 09:41 PM
Posts: 3,396 Pa
Hot 340
Pa
I often wonder if half groove bearings have any part in new flat tappet cam failures.
on a stock block the lifters get oil before the crank so I would say no. and I have never used any thing but half groove bearings and never had any problems from it.
Im speaking in respect of the cam getting less oil flung on it because the rods oil half as much.
[Re: 52savoy]
#1464811
07/08/13 09:54 PM
07/08/13 09:54 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Oh well it worked years ago and it still works for me now. Ron
[Re: 383man]
#1464812
07/09/13 07:35 PM
07/09/13 07:35 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I feel our mopars have some rod bearing starvation issues. Narrow full grooves help fix that IMO. Sure a 3/4 or half groove bearing might be better for the Crank itself. But I feel the Narrow full grooves are fine. Its more important to feed the rods then worry about a little loss surface area on the bearing for the crank. So for me its the Narrow Full groove bearing all the way.
