half groove bearing or full groove #1464796
07/08/13 02:14 PM
07/08/13 02:14 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Just to be sure guys, the stroker kit I want to buy from Hughes comes with 1/2 groove rod and main bearings, 2.2 journal with fillet. Some books say for a performance build I need full groove bearings. Will the half groove be ok? ( clevite 77)
Re: half groove bearing or full groove [Re: BeeSuper] #1464797
07/08/13 02:20 PM
07/08/13 02:20 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I like the full-groove ... but the NARROWER style .... Michigan bearing made them and the only place I ever saw them available was from JC Whitney ....
Re: half groove bearing or full groove [Re: BeeSuper] #1464798
07/08/13 03:06 PM
07/08/13 03:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just pulled my W-2 stroke apart the other day... it
has full groove mains and those bearings(both mains
and rods) looked like new.. I replaced them but could
have put them right back in... that engine has been
running 6 years in the race car... its going in the
Rampage now.. I replaced the bearings with the same
part number
Re: half groove bearing or full groove [Re: MR_P_BODY] #1464799
07/08/13 03:18 PM
07/08/13 03:18 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
What is actually the very best (for racing/hi-perf) is to use 3/4 grooved bearings... the top should be fully grooved; the bottom should be grooved at the outer edges ~25% per side so to allow the bottom to be solid. That design is proven to provide the bottom thrust face being solid to absorb the greatest amount of force. I think Federal-Mogul (via their "Speed Pro" line) sells 3/4 grooved bearings. ("Fully-grooved" is yester-year's technology.) You can call the Federal-Mogul Tech-Line and discuss this with them.
Re: half groove bearing or full groove [Re: Mopar Mitch] #1464800
07/08/13 03:49 PM
07/08/13 03:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they are... a well know indy builder told me
that the best is 5/8 of the diameter but we dont
have that so the 3/4 would be next... and in cases
they are hard to find for our stuff
Re: half groove bearing or full groove [Re: MR_P_BODY] #1464801
07/08/13 04:35 PM
07/08/13 04:35 PM
pennsylvania
poboyengineering Offline
pennsylvania
just looked up the speed pro line, and part 120M appears to be a 5/8 groove for a 360 crank. they appear to only be available in std and .010 sizes, but I may be reading it wrong.
edit: they are listed as 3/4 groove...still...
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: half groove bearing or full groove [Re: BeeSuper] #1464802
07/08/13 04:51 PM
07/08/13 04:51 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I would agree with Mitch that the 3/4 groove bearings are probably ideal. That said, I have used a lot of full groove mains and I've yet to see anyone have a main bearing problem that could be attributed to their use. I have seen people lose rod bearings due to insuffient oil. Given a choice between 1/2 groove and full groove, I'll use full groove everytime.
Re: half groove bearing or full groove [Re: Mopar Mitch] #1464803
07/08/13 05:20 PM
07/08/13 05:20 PM
I disagree with not oiling the rods full time all the time, especially when revving a motor above 5000 RPM I like and use the Federal Mogul truck full narrow groove main bearings
Re: half groove bearing or full groove [Re: Cab_Burge] #1464804
07/08/13 06:17 PM
07/08/13 06:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have used fully groved mains for many years. Never had a bearing problem on any of my engines. Ron
Re: half groove bearing or full groove [Re: 383man] #1464805
07/08/13 06:30 PM
07/08/13 06:30 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
groovy.... but you and Cab are yester-year's technology
Re: half groove bearing or full groove [Re: 52savoy] #1464806
07/08/13 07:36 PM
07/08/13 07:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I didn't think I was old but must be. I use full grove mains also.
Re: half groove bearing or full groove [Re: BeeSuper] #1464807
07/08/13 07:59 PM
07/08/13 07:59 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I haven't had any issues using 1/2 groove mains in anything, and have used 3/8 groove mains in a 8200 rpm build with .680" wide rod bearings.
Re: half groove bearing or full groove [Re: LSP] #1464808
07/08/13 08:52 PM
07/08/13 08:52 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I often wonder if half groove bearings have any part in new flat tappet cam failures.
Re: half groove bearing or full groove [Re: Hot 340] #1464809
07/08/13 09:01 PM
07/08/13 09:01 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
on a stock block the lifters get oil before the crank so I would say no.
and I have never used any thing but half groove bearings and never had any problems from it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: half groove bearing or full groove [Re: dusturbd340W5] #1464810
07/08/13 09:41 PM
07/08/13 09:41 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Im speaking in respect of the cam getting less oil flung on it because the rods oil half as much.
Re: half groove bearing or full groove [Re: 52savoy] #1464811
07/08/13 09:54 PM
07/08/13 09:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Oh well it worked years ago and it still works for me now. Ron
Re: half groove bearing or full groove [Re: 383man] #1464812
07/09/13 07:35 PM
07/09/13 07:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I feel our mopars have some rod bearing starvation issues. Narrow full grooves help fix that IMO.
Sure a 3/4 or half groove bearing might be better for the Crank itself. But I feel the Narrow full grooves are fine. Its more important to feed the rods then worry about a little loss surface area on the bearing for the crank.
So for me its the Narrow Full groove bearing all the way.
Re: half groove bearing or full groove [Re: 52savoy] #1464813
07/09/13 10:05 PM
07/09/13 10:05 PM
It must be great being you , a newbie with so much expereince
Re: half groove bearing or full groove [Re: Cab_Burge] #1464814
07/11/13 02:16 AM
07/11/13 02:16 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
Full grooved main bearings allow the hydrodynamic oil wedge between the journal and bearing to deplete,Nascar cup Nhra Prostock and Comp elim. most not using full grooved bearings or crossdrilled cranks.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: half groove bearing or full groove [Re: BIGSPEED] #1464815
07/12/13 07:57 AM
07/12/13 07:57 AM
pa
572charger Offline
572charger  Offline
pa
fm 119m in my hemi !!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
