Page 3 of 3 1 2 3
Re: Transmission cooler line question [Re: dizuster] #1464733
07/11/13 09:57 PM
07/11/13 09:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You guys are confusing issues here...
First of all heat DOES NOT RISE. There is nothing special in "heat" that makes it defy gravity.
The reason a hot air baloon rises is because when the air is heated, it expands and becomes less dense. The lower density air "floats" on the high density air. So the hot air goes "up".
Same thing happens in fluids. The hot fluid expands and is less dense, and therefore rises.
Heat through a solid body does not cause any change in density. Solid fins on a trans cooler do not change position. Nothing is "flowing" like happens in air or fluid.
The reason that radiators flow trans fluid from bottom is because of a principal called counter current heat exchange. This is because the hottest water can cool the very hot trans fluid effectively. The trans fluid can only be as cool as the last point of coolant temperature that it exits. It's more effective if it exits at the lower point where it's coldest.
The question at hand about trans fluid through a normal (non-coolant heater exhange like a radiator) does not apply to "heat rises" or "the OEM did it like this."
The direction on a finned fluid to air cooler does not matter at all.
Call it what ever you want... hot air goes UP and
yes I know about the density
Re: Transmission cooler line question [Re: MR_P_BODY] #1464734
07/11/13 10:22 PM
07/11/13 10:22 PM
Az
Crizila Offline
Crizila  Offline
Az
Proof: " Cheech & Chong and 'UP' in smoke".
Fastest 300
Re: Transmission cooler line question [Re: Crizila] #1464735
07/11/13 10:57 PM
07/11/13 10:57 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Cooler outlet always on top. If not, after sitting, gravity drain effect will cause slow converter charge, pan overfill and potential manual lever seal leaks.
Re: Transmission cooler line question [Re: dizuster] #1464736
07/12/13 12:49 AM
07/12/13 12:49 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Here's another curve ball, there is no such thing as cold, just absence of heat.
Re: Transmission cooler line question [Re: cudaman1969] #1464737
07/12/13 01:34 AM
07/12/13 01:34 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Someone else that wasn't asleep in science class.
Kevin
Re: Transmission cooler line question [Re: Twostick] #1464738
07/12/13 09:19 AM
07/12/13 09:19 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
And here is another twist ------
I have an external trans cooler and both hookups are facing down Should the front hose go to the left down facing connection or the right down facing connection
Just want to get it right..................
Russ
Re: Transmission cooler line question [Re: max_maniac] #1464739
07/12/13 09:48 AM
07/12/13 09:48 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Russ
Here is where you MUST take a scientific approach.
I'd suggest either a coin toss , or eeenie ,meenie , miney , moe..........
These empirical methods will never let you down.
Re: Transmission cooler line question [Re: tubtar] #1464740
07/12/13 10:12 AM
07/12/13 10:12 AM
west palm beach, florida
modelmakerinc Online content
modelmakerinc  Online Content
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Transmission cooler line question [Re: tubtar] #1464741
07/12/13 11:11 AM
07/12/13 11:11 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Russ
I have seen them laying flat on the back of dragsters with the inlet/outlet pointing toward the front also, just like I said before,,,it don't matter, as long as you get air flow across it,,we could sit here and debate this till the cow's come home.
Page 3 of 3 1 2 3
