B-body Window Channel -- Help! #1464033
07/07/13 04:14 PM
07/07/13 04:14 PM
Pennsylvania
moparsenior Offline OP
Pennsylvania
I'd like to replace the window channel/run in front door of B-body POST-CAR (2dr sdn not HT). After removing door panel, I've backed away!
Q) How does one gain access to inside of this door, and how do you replace channel?
I'm thinking I might have bitten off more than I can chew.
Has anyone done this?
Re: B-body Window Channel -- Help! [Re: moparsenior] #1464034
07/07/13 04:29 PM
07/07/13 04:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you have to remove the glass. the channel is attached to the glass with plastic/nylon holders/glides.
Re: B-body Window Channel -- Help! [Re: mikemee1331] #1464035
07/07/13 05:10 PM
07/07/13 05:10 PM
Pennsylvania
Pennsylvania
Don't think we're on the same page. I might be using wrong terminolgy; or you might be talking about a different year B-body.
I have '66 Coronet post car with window channel attached to inside of door. I can probably get the glass out, but the channel is not attached to glass. There is a plastic rivet holding glass to a lift bracket, but this does not help in getting one's hand inside the door in order to remove or re-install the rubber run.
Let's try again.
Re: B-body Window Channel -- Help! [Re: moparsenior] #1464036
07/07/13 05:20 PM
07/07/13 05:20 PM
The Tree Offline
The Tree  Offline
Get yourself a download of the 66 parts catalog from mymopar.com and then find the window section for your sedan. good exploded views.
May be some other ref at that site to help also.
Best of luck,
Randy
Re: B-body Window Channel -- Help! [Re: moparsenior] #1464037
07/07/13 05:42 PM
07/07/13 05:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Let's try again.
sorry, i should have asked you to be more specific.
Re: B-body Window Channel -- Help! [Re: mikemee1331] #1464038
07/08/13 10:12 AM
07/08/13 10:12 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I believe you need to push out the center part of this plastic rivet which then unlocks the outside part of the rivet..
