Brake problem. #1463941
07/07/13 01:54 PM
07/07/13 01:54 PM
WI, USA
cdummer43 Offline OP
WI, USA
So now it is July and my car still is not on the road due to a couple of things. The main concern is my brakes. For some background the brakes that I am having an issue with is on a 1974 Dodge Rallye Challenger with disc brakes up front and drums in the rear.
Problem: I have bled the brakes properly, and when I got the car running again after redoing the engine compartment I wanted to take it for a drive so I could see how it ran and adjust the timing accordingly. But when I was checking to see if the brakes worked properly in the driveway before finding out the hard way down the road, the pedal went all the way to the floor and stayed there. The brakes were completely locked up (making it apparent that the system was properly bled). I actually had to turn the car off to release the brakes. Now I am thinking that my remanufactured brake booster may have taken a turn for the worse on me, but just to be sure I am addressing this problem to you other gear heads for some input. it would be much appreciated if you could help a fellow Mopar man out. Thanks guys/gals.
Re: Brake problem. [Re: cdummer43] #1463942
07/07/13 03:08 PM
07/07/13 03:08 PM
Andrewh Offline
Andrewh  Offline
disconnect the vacuum to the booster, and try again.
if it releases but is just harder to push, then the internal valve died and won't reset to let the pedal go.
Re: Brake problem. [Re: Andrewh] #1463943
07/07/13 04:31 PM
07/07/13 04:31 PM
WI, USA
WI, USA
Yeah when I disconnect the booster (for manual brakes) the pedal releases. So what your telling me is that I need to get a new booster?
Re: Brake problem. [Re: cdummer43] #1463944
07/07/13 05:07 PM
07/07/13 05:07 PM
Andrewh Offline
Andrewh  Offline
yep or get it rebuilt. the internal valve that bleeds off and releases when you let off the pedal is messed up.
Re: Brake problem. [Re: Andrewh] #1463945
07/07/13 10:34 PM
07/07/13 10:34 PM
WI, USA
WI, USA
Thanks a lot boss. had to order the new one that Bendix makes for Mopar from Yearone, cost me an arm and a leg but hopefully that solves the problem seeing as though all the auto parts store around me do not have any remanufactured ones available to them.
Re: Brake problem. [Re: cdummer43] #1463946
07/08/13 01:16 AM
07/08/13 01:16 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Cody read this. You will have a masters degree in Brake Systems... Good Luck
Re: Brake problem. [Re: MAVERICKSHEMI] #1463947
07/08/13 06:19 AM
07/08/13 06:19 AM
WI, USA
WI, USA
@MAVERICKSHEMI reads what? if it is a document send it to my email, cdummer43@gmail.com
