Re: Carter Thermoquad, epoxy for center section question
[Re: bigblock340power]
#1463925
07/07/13 07:25 PM
07/07/13 07:25 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I can tell you what doesn't work. I tried a fuel tank leak repair epoxy. Search back for details. Came as a roll that you cut a kneaded. Anyway, it lasted about a year. I ended up replacing the carb.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1463926
07/07/13 08:48 PM
07/07/13 08:48 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Ok, now I know what not to use. How about what I can use?
#1463927
07/07/13 09:12 PM
07/07/13 09:12 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
pretty sure we just used JB Weld in the carb restoration shop I worked in. Clean the parts well, hit em lightly with sandpaper to get nice flat surfaces and it should see very little contact with gas. slather a good amount around the outside of the seam afterward to help. if you can find one of the foam inserts used to put upward pressure on the similar part on Q-Jets you can cut those in half and put them underneath to help also.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
