Carter Thermoquad, epoxy for center section question #1463924
07/07/13 12:30 PM
07/07/13 12:30 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
What's the best stuff to use for epoxying the plastic center section of a Carter Thermoquad? Got to be strong, permanent, and gas (or any other junk they put in gas now a days) resistant.
Re: Carter Thermoquad, epoxy for center section question [Re: bigblock340power] #1463925
07/07/13 07:25 PM
07/07/13 07:25 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I can tell you what doesn't work. I tried a fuel tank leak repair epoxy. Search back for details. Came as a roll that you cut a kneaded. Anyway, it lasted about a year.
I ended up replacing the carb.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Carter Thermoquad, epoxy for center section question [Re: 471Magnum] #1463926
07/07/13 08:48 PM
07/07/13 08:48 PM
Elk Grove, Calif.
Elk Grove, Calif.
Ok, now I know what not to use. How about what I can use?
Re: Carter Thermoquad, epoxy for center section question [Re: bigblock340power] #1463927
07/07/13 09:12 PM
07/07/13 09:12 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
pretty sure we just used JB Weld in the carb restoration shop I worked in. Clean the parts well, hit em lightly with sandpaper to get nice flat surfaces and it should see very little contact with gas. slather a good amount around the outside of the seam afterward to help. if you can find one of the foam inserts used to put upward pressure on the similar part on Q-Jets you can cut those in half and put them underneath to help also.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Carter Thermoquad, epoxy for center section question [Re: Michael Ecks] #1463928
07/08/13 06:57 AM
07/08/13 06:57 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Use 'Marine-tex' Rapid-Set gray. Holds up to alcohol blended gas better than JB. Dave
