'71 GTX with a leaning antenna #1462875
07/04/13 05:46 PM
07/04/13 05:46 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
I've got a '71 GTX with a stock reproduction antenna.
The base plate for it sits flush against the fender..but..the hole in the top of the fender is on an angle due to the fender being roundish, so my antenna is leaning awkwardly away from the car.
Does the antenna bend at the very base above the bezel?
Did they used to have shims that I'm not seeing?
Thank you.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: '71 GTX with a leaning antenna [Re: NOrrTH] #1462876
07/04/13 05:58 PM
07/04/13 05:58 PM
Georgia,Douglasville
streaker Offline
streaker  Offline
I think you need to rotate the bezel. Isn't one side is thicker than the other?
I said Don't look Ethel, It was too late
Re: '71 GTX with a leaning antenna [Re: NOrrTH] #1462877
07/04/13 06:02 PM
07/04/13 06:02 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
From memory, the top bezel is curved on the 71/72 fenders to let the mast point straight up.
That bezel should be your solution, I think everything else would be the same. Here's an auction for one and you can see how one side is lower than the other.
http://www.ebay.com/itm/Mopar-71-72-73-Roadrunner-GTX-Satellite-Antenna-Bezel-/171022684193
Mike.
Re: '71 GTX with a leaning antenna [Re: NOrrTH] #1462878
07/04/13 06:48 PM
07/04/13 06:48 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
Thank you.
\the one you have has the offset in it already,u can see it in the picture
Re: '71 GTX with a leaning antenna [Re: NOrrTH] #1462879
07/04/13 06:53 PM
07/04/13 06:53 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
look at your bezel. one side is thicker than the other. the thicker side should be located towards the outermost part on the fender.
Re: '71 GTX with a leaning antenna [Re: Golden-Arm] #1462880
07/04/13 06:56 PM
07/04/13 06:56 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Aye...
Re: '71 GTX with a leaning antenna [Re: NOrrTH] #1462881
07/04/13 09:38 PM
07/04/13 09:38 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
The last repop antenna I bought came with the wrong chrome bezel which made the antenna sit crooked. Mine was for a cuda but maybe you have the same issue? I found the proper bezel which fixed it.
Just out of curiosity, where did you buy it? Mine came from Dales Cuda shop, not bashing them but I know there were a couple people who had that problem.
Re: '71 GTX with a leaning antenna [Re: 4004spd] #1462882
07/06/13 11:14 PM
07/06/13 11:14 PM
Ripley, NY
tcat446 Offline
tcat446  Offline
Ripley, NY
So do (ALL) the ones from Dale's do this? Or have they straightened it out? I was gonna call and order one on Monday.
Re: '71 GTX with a leaning antenna [Re: tcat446] #1462883
07/07/13 04:36 PM
07/07/13 04:36 PM
Ripley, NY
tcat446 Offline
tcat446  Offline
Ripley, NY
Anyone??
Re: '71 GTX with a leaning antenna [Re: tcat446] #1462884
07/07/13 07:19 PM
07/07/13 07:19 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Got the same issue on my 72. Definitely interested in finding a solution.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: '71 GTX with a leaning antenna [Re: 471Magnum] #1462885
07/07/13 09:16 PM
07/07/13 09:16 PM
Ripley, NY
tcat446 Offline
tcat446  Offline
Ripley, NY
With my old bezel it is straight. If I get it and its not straight, I'm having the original bezel that sits right, re chromed. I will post my findings.
Re: '71 GTX with a leaning antenna [Re: tcat446] #1462886
07/08/13 06:53 PM
07/08/13 06:53 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
I purchased a repop from Year One many years ago, and the antenna sits straight with it....
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: '71 GTX with a leaning antenna [Re: Butterscotch71] #1462887
07/13/13 12:50 AM
07/13/13 12:50 AM
Ripley, NY
tcat446 Offline
tcat446  Offline
Ripley, NY
Yep the one from Dales Cuda shop worked great. Fit nice and all is well.
