Oil pressure change w/ roller lifters in unbushed BB? #1462342
07/03/13 05:55 PM
07/03/13 05:55 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I'm wondering if people have seen a reduction in oil pressure when switching from flat-tappet lifters (hyd or solid) to solid roller lifters in OEM big blocks w/ unbushed lifter bores.
FWIW, I'm going to be using the roller lifters that Brian @ IMM used to offer, which have a cut-out in the middle of the body comparable to the COMP 892s. Here's a picture of the IMM lifter, although mine have the offset intake pushrod seat.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462343
07/03/13 06:18 PM
07/03/13 06:18 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I went from flat tappets to a solid roller and noticed a pressure drop at warm idle, even though I have CompCams' 'fullbody' lifters.
But I also exchanged 1.6 Crane gold rockers for 1.5 needlebearing rockers, so the pressure drop could also be a result from that. More likely the latter I would think.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462344
07/03/13 06:54 PM
07/03/13 06:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I did when I ran the Isky Red-zones because of the cutaway on the body like yours but now run the solid body lifter w/out issues.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: Thumperdart] #1462345
07/03/13 08:01 PM
07/03/13 08:01 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
It would depend on how much lift you are going to run on the cam, I used to run the Cranes with the cutaways, and they were fine with a .625 cam, had room to spare, now run solid body with a .675 cam, I think the Cranes would have worked fine with the bigger cam also, they were replaced because they just finally wore out, no complaints on that though, I had bought them used.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: Thumperdart] #1462346
07/03/13 08:13 PM
07/03/13 08:13 PM
new york
68HEMIRR Offline
68HEMIRR  Offline
new york
you run a solid body isky rollers?....or what lifters are you running now?.....i am dumping my schubeck ceramic solid lifters and going with solid rollers......just curious...thanks
BORN TO BE WILD
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: 68HEMIRR] #1462347
07/03/13 09:57 PM
07/03/13 09:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use Comp 848's in my engine and a friends stock block 440.Lost 15 lbs of OP hot.Last time I freshened my hemi after 3 years of abuse,had restrictors installed in the pushrods and got that 15 lbs back.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: hemi-itis] #1462348
07/03/13 10:02 PM
07/03/13 10:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I run the solid body comps and psi was fine and even put a restrictor in the ds rear oil galley when I had a stock block.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: hemi-itis] #1462349
07/03/13 10:04 PM
07/03/13 10:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Anyone ever use these towards the bottom of the page? http://www.mrlperformance.com/
Mopar to the bone!!!
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: 72Swinger] #1462350
07/03/13 11:11 PM
07/03/13 11:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what it's worth I have bushed lifter bores. With push rod oil (.080 holes in the pushrods) and .003" bearing clearance I couldn't make over 40 psi hot w/ vacuum pump at 10psi. Reducing the the lifter feed holes from 2 @.110 to 1 @.040 I then had to back off the oil pump relief valve adjustment .200" to get back down to 70psi. Just shows you how much volume you can lose in that area.
Doug
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: 68HEMIRR] #1462351
07/04/13 01:41 AM
07/04/13 01:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes, solid body Isky`s that have been rebuilt once.............
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: Thumperdart] #1462352
07/04/13 07:29 AM
07/04/13 07:29 AM
The Great White North
RAMM Offline
RAMM  Offline
With those lifters in the picture you will experience low oil pressure at idle. The good news is that it doesn't cause any damage. I have done multiple inspections on big blocks with 15-20 lbs idle oil pressure with those lifters and the bearings looked new. I would still look into bushing the bores or a full body lifter at the right diameter. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: RAMM] #1462353
07/04/13 11:41 AM
07/04/13 11:41 AM
BradH Offline OP
BradH  Offline OP
If there was such a thing as a full-body lifter w/ offset intake seats and EDM oiling of the bearings, that would be the hot setup. There may be something out there now that fits that description, but with my luck it's a $1000 set of lifters...
I don't need pushrod oiling, but the other features would fit my application better IF the cut-out band is (and this seems to be a point of contention) the reason for the difference in oil pressure.
Some builders say the cutout results in the lower oil pressure, while others have said that problem is a result of the lifter body not extending far enough down over the roller itself, thus exposing the oil gallery in the lifter bore to an open passage at peak lifter rise.
I'm looking at a cam w/ a .434" lobe lift, so that "should" still be in the safe range from what I recall discussing w/ Brian when I purchased the lifters.
This will be my first "roller rodeo", so I have to admit ignorance on the issue and am trying to be prepared for what may result.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462354
07/04/13 12:05 PM
07/04/13 12:05 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know if you have the original IMM lifters or the revised ones.
One was noticably taller than the other (2.25" compared to 1.78" in my picture of Comp 892)
FWIW, this is what I measured on Comp 892. No noticable problem with a 0.434" lobe lift. But I didn't idle the car much to observe it either. I do remember doing a check when putting them in the 400 block. The oil galley was nowhere near being exposed at max lift or the base circle.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: 440Jim] #1462355
07/05/13 01:27 PM
07/05/13 01:27 PM
BradH Offline OP
BradH  Offline OP
FWIW, I put a cam in my unbushed 451 block and dropped all the IMM lifters in to try and determine whether that cam / lifter / block combination was exposing the lifter bore oil gallery openings at peak lobe lift. If my measurements are reasonably accurate (some of them are "eyeballed" by putting vernier down into the lifter bores, this particular parts combination appears to be leaving the bottom of the oil gallery passage covered by approx. .080" of lifter skirt... at least on the bore that I measured.
Knowing how much variance the old Chrysler castings have, I can see where this might be hit-or-miss on whether each lifter / bore combination manages to cover the oil gallery passage at all times, or allows a small opening as the lobe reaches peak lift.
As Brian @ IMM mentioned previously (older thread), he's suggested some of his customers to have cams ground on smaller diameter base circles to reduce the likelihood of this happening. I'd have to measure the base circle on this particular cam to get any reference # for comparison, and wouldn't know w/o other people providing additional measurements on whether what I have falls into the "big", "average" or "small" base circle.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: 440Jim] #1462356
07/05/13 01:33 PM
07/05/13 01:33 PM
BradH Offline OP
BradH  Offline OP
Actually, I have a set of each, both w/ the offset intake pushrod seats. The revised "short body" set I purchased new directly from Brian. The original "long body" set I purchased as low-use used units from Jason Nimitz.
Other than the extended height of the body above the pushrod seats, the rest of the dimensions are identical from what I can tell. I prefer the "long body" style because I believe they're more stable in the lifter bores, but haven't seen those around since Brian sold out of the original lifters before I bought some from his later inventory.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462357
07/05/13 01:37 PM
07/05/13 01:37 PM
BradH Offline OP
BradH  Offline OP
For the people who have seen a reduction in oil pressure, is this only at apparent idle, or does it reduce the pressure across the entire RPM range? I figured if it's across the whole RPM range, running a stiffer oil pressure relief spring might help to band-aid the reduced pressure.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462358
07/05/13 02:06 PM
07/05/13 02:06 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
One of the many reason I am putting 1.7 ratio rockers on my 511 is the ability to use a smaller base circle cam.
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: BradH] #1462359
07/05/13 03:03 PM
07/05/13 03:03 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
The problem isn't pressure, it's volume , un bushed lifter bores allow to much volume to feed the top end in most mopar applications. you can put the stiffest oil pump spring you can find, if there's not enough volume you will never build a ton of pressure...
Re: Oil pressure change w/ roller lifters in unbushed BB? [Re: boatracer572] #1462360
07/06/13 09:35 AM
07/06/13 09:35 AM
BradH Offline OP
BradH  Offline OP
... un bushed lifter bores allow to much volume to feed the top end in most mopar applications...
But that only applies if you're working w/ lifters where the pushrod oil feed ports are exposed to the oil gallery most/all of the time.
The issue I'm talking about is when the lifter body rises enough to momentarily expose the oil gallery at full lobe lift, which wouldn't have any impact on the amount of oil being pumped up to the top end.
