Re: Oil pressure change w/ roller lifters in unbushed BB?
[Re: Thumperdart]
#1462345
07/03/13 08:01 PM
07/03/13 08:01 PM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
It would depend on how much lift you are going to run on the cam, I used to run the Cranes with the cutaways, and they were fine with a .625 cam, had room to spare, now run solid body with a .675 cam, I think the Cranes would have worked fine with the bigger cam also, they were replaced because they just finally wore out, no complaints on that though, I had bought them used.
[Re: Thumperdart]
#1462352
07/04/13 07:29 AM
07/04/13 07:29 AM
Posts: 1,051 The Great White North
RAMM
With those lifters in the picture you will experience low oil pressure at idle. The good news is that it doesn't cause any damage. I have done multiple inspections on big blocks with 15-20 lbs idle oil pressure with those lifters and the bearings looked new. I would still look into bushing the bores or a full body lifter at the right diameter. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1462353
07/04/13 11:41 AM
07/04/13 11:41 AM
BradH
If there was such a thing as a full-body lifter w/ offset intake seats and EDM oiling of the bearings, that would be the hot setup. There may be something out there now that fits that description, but with my luck it's a $1000 set of lifters... I don't need pushrod oiling, but the other features would fit my application better IF the cut-out band is (and this seems to be a point of contention) the reason for the difference in oil pressure. Some builders say the cutout results in the lower oil pressure, while others have said that problem is a result of the lifter body not extending far enough down over the roller itself, thus exposing the oil gallery in the lifter bore to an open passage at peak lifter rise. I'm looking at a cam w/ a .434" lobe lift, so that "should" still be in the safe range from what I recall discussing w/ Brian when I purchased the lifters. This will be my first "roller rodeo", so I have to admit ignorance on the issue and am trying to be prepared for what may result.
[Re: 440Jim]
#1462355
07/05/13 01:27 PM
07/05/13 01:27 PM
BradH
FWIW, I put a cam in my unbushed 451 block and dropped all the IMM lifters in to try and determine whether that cam / lifter / block combination was exposing the lifter bore oil gallery openings at peak lobe lift. If my measurements are reasonably accurate (some of them are "eyeballed" by putting vernier down into the lifter bores, this particular parts combination appears to be leaving the bottom of the oil gallery passage covered by approx. .080" of lifter skirt... at least on the bore that I measured. Knowing how much variance the old Chrysler castings have, I can see where this might be hit-or-miss on whether each lifter / bore combination manages to cover the oil gallery passage at all times, or allows a small opening as the lobe reaches peak lift. As Brian @ IMM mentioned previously (older thread), he's suggested some of his customers to have cams ground on smaller diameter base circles to reduce the likelihood of this happening. I'd have to measure the base circle on this particular cam to get any reference # for comparison, and wouldn't know w/o other people providing additional measurements on whether what I have falls into the "big", "average" or "small" base circle.
[Re: 440Jim]
#1462356
07/05/13 01:33 PM
07/05/13 01:33 PM
BradH
I don't know if you have the original IMM lifters or the revised ones.
Actually, I have a set of each, both w/ the offset intake pushrod seats. The revised "short body" set I purchased new directly from Brian. The original "long body" set I purchased as low-use used units from Jason Nimitz.
Other than the extended height of the body above the pushrod seats, the rest of the dimensions are identical from what I can tell. I prefer the "long body" style because I believe they're more stable in the lifter bores, but haven't seen those around since Brian sold out of the original lifters before I bought some from his later inventory.
[Re: boatracer572]
#1462360
07/06/13 09:35 AM
07/06/13 09:35 AM
BradH
... un bushed lifter bores allow to much volume to feed the top end in most mopar applications...
But that only applies if you're working w/ lifters where the pushrod oil feed ports are exposed to the oil gallery most/all of the time.
The issue I'm talking about is when the lifter body rises enough to momentarily expose the oil gallery at full lobe lift, which wouldn't have any impact on the amount of oil being pumped up to the top end.
