steering column #1462072
07/03/13 03:01 AM
07/03/13 03:01 AM
san francisco
dawgfather Offline OP
san francisco
hey guys I am trying to take apart my steering column... I am hitting a snag at the bottom. I don't know what it is called but I have attached a picture to show you what it is and there is a pin that holds it in place I think and I am trying to get the pin out.. let me know if I am approaching this the wrong way and if you guys have a better way of taking this apart please let me know.. thanks
Re: steering column [Re: dawgfather] #1462073
07/03/13 08:13 AM
07/03/13 08:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the roll pin at the bottom holds the column into the steering box. The coupler (the thing you are looking at) should basically just pull off. It has a couple of retainers in it and a pin. And it should be full of thick black grease.
Coming soon!!!!
Re: steering column [Re: Mr.Yuck] #1462074
07/03/13 11:20 AM
07/03/13 11:20 AM
Ohio
dobie Offline
dobie  Offline
Ohio
I rebuilt mine last year. That pin was a bear to get out at first. I just used a big punch, and a bigger hammer and eventually it came out.
1968 Plymouth Road Runner 383 4 speed
Re: steering column [Re: dawgfather] #1462075
07/03/13 11:39 AM
07/03/13 11:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's called a roll pin, it's a 5/16" roll pin. A 5/16" roll pin punch makes easy work of removing one.
Then there's 1/16" pin that must be slid back to get the shoes out, real easy to do with a pair of channel locks or simular tool.
Re: steering column [Re: Challenger 1] #1462076
07/03/13 01:38 PM
07/03/13 01:38 PM
san francisco
san francisco
I am guessing that I can punch it through and when I put it back I just put it back from the outside and punch it in right..? thanks again guys..!!
