MOD MAN Indy SB Intake #1461641
07/02/13 09:33 AM
07/02/13 09:33 AM
Muncie
Racebuddy Offline OP
Muncie
The Indy Cylinder Head MOD MAN SB Intake
Do they make any power on a 418 stroker???
Is the single planes out performing them??
Re: MOD MAN Indy SB Intake [Re: Racebuddy] #1461642
07/02/13 08:28 PM
07/02/13 08:28 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's not a manifold you're going to make big power with, it's selling point is it's very universal and probably aimed more toward Street Rodders etc.
Alan Jones
Re: MOD MAN Indy SB Intake [Re: Racebuddy] #1461643
07/02/13 08:55 PM
07/02/13 08:55 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
No.
Stick with a single plane.
School of Automotive Machinists Racing
Re: MOD MAN Indy SB Intake [Re: moparman89] #1461644
07/03/13 10:24 AM
07/03/13 10:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Can't tell you about the sb intake but at the risk of saying something nice about Indy, we put the mod man 2 4bbl intake on my buddy's 572 hemi and it was within .03 of a $3,000 Ray Barton intake. I was impressed.
2011 Drag Pak Challenger
Re: MOD MAN Indy SB Intake [Re: rickseeman] #1461645
07/05/13 05:37 AM
07/05/13 05:37 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Ill have some dyno figs shortly, but as its a carb inducted G3 HEMI, there wont be much to compare it to .
I can say my jetting has been a little weird compared to my M1 inducted stroker smallblock....but that could be due to the motor as much as the intake.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: MOD MAN Indy SB Intake [Re: moparman89] #1461646
07/05/13 09:36 AM
07/05/13 09:36 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
No.
what makes you say this? Any firsthand info?
Re: MOD MAN Indy SB Intake [Re: Hot 340] #1461647
07/05/13 10:23 AM
07/05/13 10:23 AM
Muncie
Muncie
I think they look great and I want one but
I don't want to give up 30hp by using it instead of the W-2 Victor Jr or something like that.
if they are close in numbers I will go for it !
Re: MOD MAN Indy SB Intake [Re: Racebuddy] #1461648
07/05/13 10:34 AM
07/05/13 10:34 AM
Idaho
LaRoy Engines Offline
Idaho
The Mod Man looks cool, but.........
Watched a small block dyno swap from Edelbrock single plane to the Indy Mod Man and witnessed a considerable power loss with the Mod Man.
Don't remember the exact horsepower numbers, but many watching had predicted the loss just by looking at the manifold, we were correct.
It just kinda reminded me of the old Weiand 6-2bbl DragStar manifolds from the 1950's for the big blocks.
Re: MOD MAN Indy SB Intake [Re: LaRoy Engines] #1461649
07/05/13 12:29 PM
07/05/13 12:29 PM
The Great White North
RAMM Offline
RAMM  Offline
Sure looks like WAY too much plenum and NOT nearly enough runner length combined with too much CSA. Might work good with positive manifold pressure.though. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: MOD MAN Indy SB Intake [Re: RAMM] #1461650
07/05/13 08:08 PM
07/05/13 08:08 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
my experience is only with the big block version so it can only be seen in that context .
After use - dyno and track time . Plenum is too big for optimum in stock cubes,i run a stock stroke 440 .
Made the same peak power as my M1 single plane but had to jet very rich due to what appeared to be poor signal . This led to very slow 60' at the track though on the street was not apparent .I did add an insert after this , about 10% volume reduction , this helped a little plus fitted 1" 4 hole spacers this also helped . I have since fitted better flowing heads which should see an improvement , will try again at the end of the year . I know a guy on here has run a small block six pack but if I remember he also found he needed 2" 2 hole spacers which helped in power improvements .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: MOD MAN Indy SB Intake [Re: Hot 340] #1461651
07/06/13 01:07 AM
07/06/13 01:07 AM
Indy
moparman89 Offline
moparman89  Offline
Indy
No.
I've dyno'd quite a few small blocks with M1, Indy single four, and mod mans. The mod man is always down on power. Its only cool for a show car/cruiser piece.
Re: MOD MAN Indy SB Intake [Re: RAMM] #1461652
07/06/13 09:41 AM
07/06/13 09:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Sure looks like WAY too much plenum and NOT nearly enough runner length combined with too much CSA...
The first time I saw one "opened up", my first thought was "My 1st grader could have designed that thing...".
I'm surprised the poster above mentioned seeing how well it worked on a race Hemi, considering what IMO is an intake w/ a serious lack of emphasis on actual functionality and more on its Cool Factor.
Re: MOD MAN Indy SB Intake [Re: BradH] #1461653
07/07/13 12:18 PM
07/07/13 12:18 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Ran on on my Dart with a Hemi and made more power than a stock X-ram.We have a customer with a 528" hemi and he loves it for the street driveability over his single 1050 set up.Another customers has gone mid nines at 3600# with a Hemi,my Dart has run 9.75 with 10.0 CR and 12" tires.Haven't tried on on a small block.The open plemum doesn't seem to hurt it,similar to a StageV intake.It works well with Edelbrock 750s and 800s on the Hemis.
Re: MOD MAN Indy SB Intake [Re: B G Racing] #1461654
07/07/13 12:53 PM
07/07/13 12:53 PM
BradH Offline
BradH  Offline
Bob - Are the applications where you've seen it work "big" (500"+) displacement engines where the large plenum is likely less of a downside than on smaller displacement combinations?
Re: MOD MAN Indy SB Intake [Re: moparman89] #1461655
07/07/13 01:32 PM
07/07/13 01:32 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
No.
Which was better between the M1 and the Indy single?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: MOD MAN Indy SB Intake [Re: BradH] #1461656
07/07/13 05:34 PM
07/07/13 05:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Brad,as mentioned these were Hemis and yes they were 500",528" and 572".We would love to do a small block,416" to 472" with that combo.
Re: MOD MAN Indy SB Intake [Re: B G Racing] #1461657
07/08/13 11:51 PM
07/08/13 11:51 PM
Moparmal Offline
Moparmal  Offline
FWIW and as I posted earlier..I've found the jetting to be very strange in my application.
Using an 800 cfm edelbrock thunder...my primary jetting is around .110......but my metering rod is .075 x .037.
So basically to get it lean enough at cruise, its too lean at part throttle, and if I lean out the primAries it makes the part throttle stage too lean.
Basically I need a rod that is .080 x .030!!
Im not sure if this huge gap between cruise and part throttle is down tothe intake or the motor (G3 6.1)......but its a devil to tune right with such a difference in fuel demand.
ATM I have the AF at 12.5 at WOT.....its just the primary stages that are fickle
Maybe a poor signal?
