Re: MOD MAN Indy SB Intake
[Re: Racebuddy]
#1461642
07/02/13 08:28 PM
07/02/13 08:28 PM
Posts: 6,142 Melbourne , Australia
LA360
It's not a manifold you're going to make big power with, it's selling point is it's very universal and probably aimed more toward Street Rodders etc.
Alan Jones
[Re: Racebuddy]
#1461643
07/02/13 08:55 PM
07/02/13 08:55 PM
Posts: 171 Indy
moparman89
Indy
No.
Stick with a single plane.
School of Automotive Machinists Racing
[Re: moparman89]
#1461644
07/03/13 10:24 AM
07/03/13 10:24 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Can't tell you about the sb intake but at the risk of saying something nice about Indy, we put the mod man 2 4bbl intake on my buddy's 572 hemi and it was within .03 of a $3,000 Ray Barton intake. I was impressed.
2011 Drag Pak Challenger
[Re: rickseeman]
#1461645
07/05/13 05:37 AM
07/05/13 05:37 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Ill have some dyno figs shortly, but as its a carb inducted G3 HEMI, there wont be much to compare it to .
I can say my jetting has been a little weird compared to my M1 inducted stroker smallblock....but that could be due to the motor as much as the intake.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: moparman89]
#1461646
07/05/13 09:36 AM
07/05/13 09:36 AM
Posts: 3,395 Pa
Hot 340
Pa
No.
what makes you say this? Any firsthand info?
[Re: Racebuddy]
#1461648
07/05/13 10:34 AM
07/05/13 10:34 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
The Mod Man looks cool, but.........
Watched a small block dyno swap from Edelbrock single plane to the Indy Mod Man and witnessed a considerable power loss with the Mod Man.
Don't remember the exact horsepower numbers, but many watching had predicted the loss just by looking at the manifold, we were correct.
It just kinda reminded me of the old Weiand 6-2bbl DragStar manifolds from the 1950's for the big blocks.
[Re: LaRoy Engines]
#1461649
07/05/13 12:29 PM
07/05/13 12:29 PM
Posts: 1,051 The Great White North
RAMM
Sure looks like WAY too much plenum and NOT nearly enough runner length combined with too much CSA. Might work good with positive manifold pressure.though. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1461650
07/05/13 08:08 PM
07/05/13 08:08 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
my experience is only with the big block version so it can only be seen in that context . After use - dyno and track time . Plenum is too big for optimum in stock cubes,i run a stock stroke 440 . Made the same peak power as my M1 single plane but had to jet very rich due to what appeared to be poor signal . This led to very slow 60' at the track though on the street was not apparent .I did add an insert after this , about 10% volume reduction , this helped a little plus fitted 1" 4 hole spacers this also helped . I have since fitted better flowing heads which should see an improvement , will try again at the end of the year . I know a guy on here has run a small block six pack but if I remember he also found he needed 2" 2 hole spacers which helped in power improvements .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: RAMM]
#1461652
07/06/13 09:41 AM
07/06/13 09:41 AM
BradH
Sure looks like WAY too much plenum and NOT nearly enough runner length combined with too much CSA...
The first time I saw one "opened up", my first thought was "My 1st grader could have designed that thing...".
I'm surprised the poster above mentioned seeing how well it worked on a race Hemi, considering what IMO is an intake w/ a serious lack of emphasis on actual functionality and more on its Cool Factor.
[Re: BradH]
#1461656
07/07/13 05:34 PM
07/07/13 05:34 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Bob - Are the applications where you've seen it work "big" (500"+) displacement engines where the large plenum is likely less of a downside than on smaller displacement combinations?
Brad,as mentioned these were Hemis and yes they were 500",528" and 572".We would love to do a small block,416" to 472" with that combo.
[Re: B G Racing]
#1461657
07/08/13 11:51 PM
07/08/13 11:51 PM
Moparmal
FWIW and as I posted earlier..I've found the jetting to be very strange in my application. Using an 800 cfm edelbrock thunder...my primary jetting is around .110......but my metering rod is .075 x .037. So basically to get it lean enough at cruise, its too lean at part throttle, and if I lean out the primAries it makes the part throttle stage too lean. Basically I need a rod that is .080 x .030!! Im not sure if this huge gap between cruise and part throttle is down tothe intake or the motor (G3 6.1)......but its a devil to tune right with such a difference in fuel demand. ATM I have the AF at 12.5 at WOT.....its just the primary stages that are fickle Maybe a poor signal?
